After about 30 minutes of AC running unit shuts off. Run light blinks 4x. Can turn unit back on and it will run another 30 minutes or so then shut off again. What's the code mean? Any ideas?
Check web site for significance of the four flashes. Could be that it is overheating and shutting down due to excessive current consumption.
I did search internet initially which is how I got to this site. I could only find information on that discussed 1, 2 and 6 flashes. Nothing on 4 flashes. Nothing in the service manual on 4 flashes.
stumped. If it was overheating and shutting down it would not start up right away like you have indicated. Try speaking on phone to one of their techies.
They won't talk to me unless I am a certified HvAC Tech. I will put my gauges on it next weekend and check the current draw on the AC line which should be no more than 9-10 amp
Bunch of cocksuckers if you ask me. Do not buy any more of their products. Meanwhile, does that unit have a timer or something that could be responsible for the shutdown after 30 minutes?
Yes, the remote will act as a timer. I did a complete reset of the remote thinking that might be the issue. No change. I guess I could try pulling the battery and turning on the unit manually to see if that makes any difference?
Maybe the timer mechanism is located in the machine and all the remote does is to turn it on/off and program it. See if there is a reset button on the AC itself or remove power to the unit for a few hours and see what happens..
They won't talk to me unless I am a certified HCAC Tech. I will put my gauges on it next weekend and check the current draw on the AC line which should be no more than 9-10 amps.
