Like what? Have explain it all above .
The alarm tells you that something's wrong something's not cooling properly or something's wrong with the defrost system if you left your doors open for quite a while it will create ice around the fan blades and that could be your noise problem. d
Disconnecting the power to your refrigerator opening the doors for about 12 hours and let it manually defrost will usually solve the problem.
Appliance 911 Sea Breeze
SOURCE: Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
SOURCE: Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
SOURCE: Want to dismantle the alarm sound.
I did this before and couldn't remember how. This works on our fridge which has a water dispenser and a bunch of buttons on the left door: Try holding the express freez and lock button for a few seconds. The beeping of the buttons should stop too. I tried countless live chats with the LG people and none of them could help me. I tried a bunch of combinations and found this one to work.
