Question about Philips 9P5031C TV
Actual picture is small
I have Philips 9P503lCl 50 inch projection TV...worked great for years. Now the picture is about 20 inch when turning the TV on
Posted by gumby2 on
  • 1 more comment
  • gumby2 Nov 19, 2007
    added comment...sometimes after the tv has been on for sometime the picture will go to normal viewing...not at all times...note I am not a TV expert but hoping I would be able to fix it...maybe an idea what this type of repair would cost...
    just looking more ideas
  • gumby2 Nov 21, 2007
    Actually I was disappointed because all of the so called experts told me to take it to a TV repair person....I already knew that solution....
paul proctor
  • 4,102 Answers
The best thing you can do is call someone out out of the local phone book as this will be cheaper than them picking the set up it could be one of two problems it is eithr a power problem witch could meen something simple as a bad solder and might need resoldering this will be relitively cheap or might need a resistor replacing also not to expensive and can be done in couple of hours or the second thing could be is the projector needs realigning this would cost next to nothing but will require calling someone out with the right tools but as the picture goes the right size after the set has been on for a while i doubt it is the projector alignment i would guess it been a solder problem as when the set has been on and got warm the problem goes away so i would say it is a solder problem you could either call someone out to do this or if you have suitable transport take it to repair shop yourself cus if you get them to pick the set up they will charge for doing this hope this is some help to you good luck
Posted on Nov 19, 2007
  • paul proctor Nov 28, 2007
    our expert advice is based on you giving us as much info as possible we our all experts in our own areas and our ratings show that but without standing next to you and having all equipment with us we can only advise you on what to do if you want to repair yourself i can tell you where to buy equipment from for about 1000 pounds uk if this is what you want let me know can tell you how to do it and what to test also will need a good soldering iron let me know what you want to do ok
Thomas Christopher
    Genius:
  • 1,601 Answers
With the picture shrinking down on the four sides it tells me that a possible power supply fault is the cause of the problem. The cost of repair will vary depending on whether you have the TV picked up or you take it to a repair shop yourself.
I would suggest the latter
  • Thomas Christopher
    Thomas Christopher Nov 21, 2007
    What was the problem with you TV?
    Most people who ask questions on this website are not repair people.
    is the is the biggest reason folks use this website, we would never want people to accidently blow up their equipment or worse injure or kill themselves or others. Playing around inside these things is very DANGEROUS. Not knowing your experience is the reason for suggesting taking broken or unworking products to repair people.
steven beasley
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
The projector is out of alignment. Special tools are needed, so you might have to take to a repairman. I have that same tv, it did that same thing last year during the superbowl, I called a repairman and he fixed it in less than an hour.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
  • steven beasley
    steven beasley Nov 21, 2007
    well, dude we can't fix it for ya, with out looking at it. it could be a lot of things and with out opening it up and physically looking at it, we are all experts here, what your trying to do is have us fix it for you. It's not that easy. sure some stuff gets solved, but with out looking at it it's impossible to tell. and once again we are not so called experts, we are higher than experts.
    Thank you and have a nice day.
I have an approxiamtely 8 yr old Magnavox 50 inch DLP t.v and when you turn it on, you can hear it power on but there is no picture. Trying to figure out whether its something that can be repaired and...
I am familiar with this model, if 8 years old do not invest any money in it as most parts are no longer available from Philips.
Saw a lot of them when only a few years old get junked.
May 25, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture shrinks to only show top half
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
May 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnavox projection screen tv. The tv
Will you have got a lot of years on this unit. There could be a lot of things wrong here are some things to check.
SMD capacitor 2009 on Small Signal Board
Check fuse on SSB location 1003
Check resistor 3306 15 ohm surface mount
audio output IC 7700 on the Small Signal Module
May 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Hitachi Projection on/off problem
Tell me what it does when you try turning it on...accordianman
Feb 17, 2008 | Hitachi 50UX57B 50" Rear Projection...
Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
did you ever get your problem fixed? i have the same problem and its frrustrating. i fyou can help me please email me at [email protected].
Thanks.
Dec 26, 2007 | Philips 50P8341 50" Rear Projection...
Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Jun 01, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Philips 9P5031C TV Logo
55 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
