Question about Thomas and Friends Toys
Songs still on thomson 6278 mp3 player after deleting
Posted by connor Pike on
5 Related Answers
Anonymous
  • 99 Answers
SOURCE: HOW CAN I DELETE SONGS OFF MY MP3
The only way is to connect it to your pc and either go into my computers and your mp3 folder to delete it that way.  The other way is when the music software comes up, you can delete the music from the mp3 player platform:()
Posted on Feb 25, 2008
Anonymous
  • 3 Answers
SOURCE: deleting
For Windows XPTM users, you are connecting the device in MTP mode to the computer by default. You will need to set the device to MSC mode, so go to the device menu\Settings\Advanced\Protocol = > Press Play/Pause key to select MSC mode which will appear as such on the screen. Reconnect the device to the computer, and you can now see those files and delete them.
DO NOT forget to set the device back to MTP mode when finished, so go to device menu\Setting\Advanced = > Select MTP mode.
Posted on May 30, 2008
Anonymous
SOURCE: i cant delete songs
you need to go into my computer find the mp3 and go into where the music files are you should be able to delete them from there
Posted on Aug 03, 2008
Anonymous
  • 7 Answers
SOURCE: Sony NWZ-S515 (2 GB) MP3 Player DELETE SONGS
log on as an administrator on your comuter and plug the mp3 player into a USB slot and then goto my computer and it will be a removable disk and double click on it and you should see songs when you double click on removable disk and if there is any folders double click on them when you want to delete it left click on it once there should be a delete button click that and it will delete
I don't have a sony mp3 player but this is a standard procedure for looking at anything in a USB port
Posted on Nov 23, 2008
Anonymous
SOURCE: GPX Audio Player MP3
I have a GPX MW3847 Audio Player. After charging the player and pressing the on button; the display flashes HOLD, then BYE and cuts off.
Posted on Nov 28, 2008
My thomson mp3 player still has music on it and ive connected it to my computer and deleted them on the computer but when i go to turn the Mp3 player there is still songs on it how do i delete?
When you connect it to the computer is it showing as a portable drive? IF so you should be able to browse it and delete them that way, or you could format it .
Jul 24, 2016 | Thomson Audio Players & Recorders
When I switch my Thomson 2GB mp3 player on, the word 'Thomson' appears on the screen and instead of showing the menu, the mp3 player switches off by itself. is my mp3 player corrupted? Darryl
the answer is yes. Your mp3 player is corrupted. It must have gotten virus from the computer you used in download songs to it.
The start-up files of the OS (Operating system) of your player is corrupted.
To fix this, you need to do a firmware update. The previous version will be deleted and a newer one will be installed. By so doing, your player will be back to normal.
Good luck.
Mar 04, 2011 | Thomson Audio Players & Recorders
Need to know how to deleate songs on my i pod
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,
right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Aug 07, 2010 | Thomson Lyra PDP2842U MP3 Player
Cant delete songs from mp3 player
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
Jan 09, 2009 | Philips HDD1630 MP3 Player
I don't no how to delete music off my Thomson mp3.
ok plug your mp3 into your computer wait for it to process. then goto Start>My Computer and then the Drive for the MP3 should be named for the Device and then open open it and goto the music files and remove the songs that you do not need. This usally works for most MP3 Players. If this helps please Rate me thanks
Dec 30, 2008 | Thomson Lyra PDP2842U MP3 Player
Deleting songs
Deleting Songs Using Windows Media Player
Use Windows Media Player to view the songs that are stored on your mp3 player - best to view them in the "Sync" tab. Find the song that you want to delete, right-click the song, and select Delete (or left-click and press Delete on your keyboard). Voila!
-Tha Mp3 Doctor
Dec 30, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs from a sa3025/37 m,p3 player
My Directions:
-Tha Mp3 Doctor
Dec 27, 2008 | Philips SA3025/37 Flash MP3 Player
Hi.i dont no how to load free songs onto a thomson lyra mp3.
Thomson sold off its CE business so many times, I don't know who owns them anymore. Their players are not compatible with iTunes songs, so if your card is for either an iTunes or a DRM-encrypted WMA, you are probably out of luck. If your card is for a song in mp3 format, then load the song onto your computer first, and then use Windows Media Player to Sync the song to your mp3 player.
Dec 09, 2008 | iLO (2 GB) MP3 Player
How do i delete songs from my mp3 player
Use Windows Media Player to delete the songs:
Use Windows Media Player to delete:
My Directions:
-Tha Mp3 Doctor
Nov 29, 2008 | Philips GoGear Flash MP3 Player
Thomson PDP2842 hangs
u may have a soft wear problem
Jan 14, 2008 | Thomson Lyra PDP2842U MP3 Player
Toys Logo
61 people viewed this question
Top Thomas and Friends Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Thomas and Friends Toy Expert? Answer questions, earn points and help others
