Cars & Trucks Logo
J
Jan der Posted on Jul 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for how to reset door entry code 2010 mercury mountaineer
Reset door code
  • Jan der
    Jan der Jul 23, 2016
    Dont have a manual either
Randy Ohler
Level 3:
  • Mercury Master 14,585 Answers
  • Posted on Jul 23, 2016
Randy Ohler
Mercury Master
Level 3:
Answers
14585
Questions
8
Helped
3946716
Points
39683
If you don't have the original code you can't. If you have an aftermarket radio, you can't. I can reset them with my scanner. But not if the radio isn't factory. I don't know if the dealer can. Call around.
1helpful
Location of 2006 Ford Explorer smart box
On Ford Explorers and Mercury Mountaineers from 2006 until the model year 2010, the default five-digit keypad code is printed on the smart junction box (SJB) under the driver's side of the dash.
https://www.yourmechanic.com/article/how-to-find-the-keyless-entry-code-on-ford-explorer-and-mercury-mountaineer
How do you rest keyless for mercury mountaineer 2002
You cannot reset the keyless entry on any ford product. You can add additional keyless entry 5 digit codes but only if you know the original code. A dealer can retrieve the original code as along as you can prove you own the vehicle. some charge for this service.
2helpful
2answers
My alarm goes off intermittently
Try resetting the alarm, using the instructions given at the link below. I'll also copy the text here.
  1. Insert the ignition/door key in the door lock on the driver's- side door of your Mountaineer.
  2. Turn the key to the lock position.
  3. Turn your key to the unlock position.
  4. Turn your key to the lock position.
  5. Turn your key to the unlock position. Your alarm is now disabled. If your key fob works, you can also press the unlock or alarm-disable button on the fob.
  6. Start the Mountaineer's engine and allow the vehicle to run for at least 10 minutes. This will allow the alarm to relearn the default settings. You must make sure that you have disabled the alarm first, however, before you attempt to start the vehicle, so that the alarm will reset itself.
http://www.ehow.com/how_5978302_reset-mercury-mountaineer-alarm.html
If these instructions don't work, you can try resetting the car's computer by unplugging the battery for half an hour. However, that will reset the keyless entry code, as you can see in the fixya article I link to at the bottom
http://www.fixya.com/cars/t4755856-we_bought_it_used_and_we_dont_know_the_k
How to reset keyless enter
The keyless entry system can not be reset. The master keyless entry code can be retrivied from the vehicle. This can be done at the dealer.
2helpful
Just bought a 2002 Mountaineer w/keyless entry. The problem is no one at the dealer knows the code. How can I reset it?
In the 2002 Mercury Mountaineer, especially with the 3rd row seat, remove the trim panels at the rear of the back door and at the tailgate on the passenger side. You will see two panels where the wall seat belt is located, remove the top panel first and then pull the lower panel out.Then pull the lower trim panel forward CAREFULLY. Towards the front (near the door opening) you will see a small black box (says Security Unit) On it in fairly small print will be the 5 digit code.
[ONE set of FIVE numbers and that is your CODE number.]
How do you reset the code on the keyless entry
It seems you have problems in locating the original code to gain entry into your mercury car,however,you will find it on the back of the door lock module,in the right trunk area or below the rear passenger window.
However,If you still desire to reset the code,the only solution to this problem is that the computer will have to be reflashed by a qualified technician.
Take care..
1helpful
2answers
Keyless door pads
Go to www.customersaskford.com - type in the text box - keyless entry - then press the "ask" button
6helpful
3answers
Entry code om drivers door
The keyless entry module is located in the rear of the vehicle on the driver's side. You will need to partially remove the left rear panel in the cargo area. You will then see the keyless entry module bolted behind a metal reinforcement bar. There is a sticker on the module that has the 5 digit entry code.
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
