Question about Stihl Saws
Ts 410 STIHL DISK CUTTER recently had a 156pounds service as cutter would not start after lots of heavy use.NOW AFTER ON A REALISTIC AVERAGE OF USAGE SINCE SERVICE:45 MINUTES MAX USAGE in 6 months
Ts 410 STIHL DISK CUTTER recently had a 156pounds service as cutter would not start after lots of heavy use.NOW AFTER ON A REALISTIC AVERAGE OF USAGE SINCE SERVICE:45 MINUTES MAX USAGE SPREAD OVER A 6 MONTH PERIOD- I HAVE THE EXACT SAME PROBLEM WHERE IT RUNS NORMALLY,STOP IT, START IT UP AGAIN, THEN GONE DOES NOT START, I'VE TRIED COMMON CHECKS ON IT BUT AS A BUILDER I HAVE ZERO KNOWLEDGE ON ENGINES. Any help..
Posted by Mini on
  • Mini
    Mini Jul 23, 2016
    This exact model
Moses Simiyu
    Habit-Forming:
    New Friend:
  • 72 Answers
It is like you overworked it and it got some efficiency fault.Kindly see a dealer closer to you.
Posted on Jul 23, 2016
Testimonial: "Thanks I dont have expert locally I took it to my local building merchants to get it serviced etc with note on replaced piston/s. I've not used it recently been in dry insulated storage it started right away but would not restart. Overworked as in the what I cut when just in use! Metal tin ribs on a Henderson garage door 3mins max after warming it up full revs etc for 30secs. Could it be compression?"
4 Related Answers
Anonymous
  • 200 Answers
SOURCE: trying to start a stihl ts 400 disc cutter i
Try cleaning the plug and spray some starting fluid in the carb.Hope this helps and Thank You for asking!!!
Posted on Jul 19, 2010
baldo134
  • 75 Answers
SOURCE: hi,my stihl ts 410 saw
Sounds like an overheating problem.
Are you working in a well-ventilated area or in direct sunlight?
Check, if you can, the temperature of the motor case.
You might have to take a break more often.
This hot summer has stressed a lot of motors and electronics.
When it shuts off you know it is trying to save itself from burnout.
Posted on Aug 29, 2011
jason webster
  • 3 Answers
SOURCE: I have a stihl ts-410 cut off saw. it will start and idle but when i squeeze the throttle it dies. how do i adjust the carb?
if this machine ran ok before this problem,and no one has adjusted the carb,then i would check the crank seals.i have just had this problem.and it was the seal on the puller side,though i replaced both whilst i was at it.hope this helps my freind.
Posted on Jan 30, 2012
Thomas Beaver
  • 2119 Answers
SOURCE: Air filter is wet with petrol and keeps cutting
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/TS410420_Manual.pdf
how to adjust carbs on 2 stroke weedeaters and chainsaws Davidsfarmison...
Posted on Oct 18, 2014
Stihl ts 400
Try some WD40. I know everybody said to do that but the throttle has some corrosion on it or rust.
Apr 23, 2014 | Hand Tools
2 year old TS410 no power recently, was serviced , correct mix but dies when pressure comes on ,blade stops, starts fine and runs idle fine-tom
Hi Thomas its probably had its high/low screws reset and whilst it runs fine on the bench under load its running weak try unscrewing the high screw out a half a turn
Aug 16, 2013 | Stihl Ts 410 420 Cut Off Saw...
Hi,my stihl ts 410 saw cuts out after about 10 minutes work,it restarts soon after then cuts out after about 10 minutes again? any ideas,thanks dave
Aug 29, 2011 | Stihl Ts 410 420 Cut Off Saw...
Where can i get a manuel for a stihl ts 350 disc cutter
Try this link for the owners manual:
http://www.stihlusa.com/stihl_ownersmanuals/TS350_Manual.pdf (4.08 mb)
Let me know if it does not work for you. It worked fine for me.
Thanks for choosing FixYa, Kelly
Aug 02, 2011 | Stihl Garden
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
compressed air works well. you really need a gun with a long skinny nozzle. for example
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Where do I find a free repair manual for Stihl FS 46
If you have a nice Stihl dealer he (or she) might be nice enought to print you the specific repair information that you may need but no place that I know of offers the complete manual for free.
Sep 06, 2010 | Oregon Scientific Complete Carburetor for...
Hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Saws Logo
622 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
