Electrical Supplies Logo
M
Mel Wright Posted on Jul 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i get spare parts for a hyundai hy3000si generator [ie] voltage regulator
I need a sealed regulator unit 12 volt 240 volt as it only produces 120 volts
Bill Boyd
Level 3:
Top Expert:
  • Electrical S... Master 53,816 Answers
  • Posted on Jul 23, 2016
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949609
Points
172802
Voltage output readings are governed by rpms of the motor
check that the engine rpms are correct by adjusting the governor setting
contact hyundai generator service center for parts
I have Generac GP8000E (G0069310) and the engine runs great but generates only 2-3 volts.
Most of the time it is the AVR that has blown. Check out our videos on how to test them.
We hold your AVR in stock and have a whole Help Center dedicated to helping people fix their Portable Generators. Check it out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
1helpful
Hi l have GX400i gen set. The motor performs well unfortunately the generator is no longer producing 240 volts. Instead the volt metre is only registering about 15 to 20 volts in total which is...
Low voltage of genset will affect the use of generator set, which is one of the common faults. This article will guide you to learn the factors that affect the voltage of generating set.
1. The unstable speed of the engine causes the unstable voltage of the generator set.
2. If the load on the generator set is too large, the voltage will be unstable.
3. The damage of the voltage regulator components of the generator causes the unit's voltage instability.
4. The poor circulation of the fuel pipe of the genset causes the unstable speed of the engine, which causes voltage instability.
https://www.dieselgeneratortech.com/diesel-generators/how-to-deal-with-low-voltage-of-diesel-generator.html
1helpful
We have an engel eclipse. We had it hooked up to 12volt and the generator and now it won't work on 12 volt. Any ideas?
http://www.engelaustralia.com.au/products_details.asp?productid=21365
While the below is not an eclipse, it is suggestive.
The only requirement needed for running your "E" or "F" series Engel Fridge - Freezer (The later Models) on a 240 volt generator is to ensure the generator you are using is A.V.R. Automatic Voltage Regulated. Please refer to your generators user manual. If it is an older generator with A.V.R., it doesn't hurt to add an in line spike protector or surge arrestor.
Engel Website
BUFFALO TOOLS 2000 WATT GENERATOR 12 VOLT OUTPUT BUT NO AMPS WILL NOT EVEN LIGHT A 12 VOLT TEST LIGHT BUT VOLT METER READS 12 V.D.C. WHAT IS WRONG ? PLEASE HELP.LABEL SAYS FOR 12 VOLT BATTERY CHARGING
have the voltage regulator system checked
in the regulator the voltage controls the amperage allowed and it that unit is not working properly then there will be no current out put
that regulator could be part of the control board for the main ac out put and may have developed a fault in the section for 12 volts on the board
there is a limit on the charge rate for the battery and if it is exceed it may have damaged that circuit or possible blown a fuse in the amperage circuit
1helpful
What is causing the battery to drain?
Running the car will drain the battery it if it's not charging ! An if your charging light is on it isn't charging ! Did you check power an grounds on the alternator ? There is a single heavier wire on the back of the alternator, this should have battery voltage ! You may want to take this to a ASE certified repair shop !
Functionality
With the ignition switch in the RUN position, voltage is applied through the warning indicator I circuit 904 (LG/RD) to the voltage regulator. This turns the regulator on, allowing current to flow from battery sense A circuit 35 (OG/LB) to the generator field coil. When the engine is started, the generator begins to generate alternating current (AC) which is internally converted to direct current (DC). This current is then supplied to the vehicle's electrical system through the output (B+) terminal of the generator.
Once the generator begins generating current, a voltage signal is taken from the generator stator and fed back to the regulator S circuit 4 (WH/BK). This voltage feedback signal (typically half the battery voltage) is used to turn off the warning indicator.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit 35 (OG/LB). The A circuit 35 (OG/LB) voltage is compared to a set voltage internal to the regulator, and the regulator controls the generator field current to maintain the correct generator output.
The set voltage will vary with temperature and is typically higher in cold temperatures and lower in warm temperatures. This allows for better battery recharge in the winter and reduces the chance of overcharging in the summer.
Battery Positive Output (B+) Circuit 38 (BK/OG)
The generator output is supplied through the battery positive output (B+) terminal on the back of the generator to the battery and electrical system.
I Circuit 904 (LG/RD)
The I (ignition) circuit 904 (LG/RD) is used to turn on the voltage regulator. This circuit is powered up with the ignition switch in the RUN position. This circuit is also used to turn the charging system warning indicator on if there is a fault in the charging system operation.
A Circuit 35 (OG/LB)
The A (battery sense) circuit 35 (OG/LB) is used to sense battery voltage. This voltage is used by the regulator to determine generator output. This circuit is used to supply current to the generator field (rotor). The amount of current supplied to the rotor will determine generator output.
S Circuit 4 (WH/BK)
The S (stator) circuit 4 (WH/BK) is used to feed back a voltage signal from the generator to the regulator. This voltage is used by the regulator to turn off the charging system warning indicator. The S circuit is fed back externally on external mounted regulator generators.
Visual Inspection Chart Mechanical Electrical
  • Battery case, posts, hold-down clamp, cables and connections
  • Generator drive (serpentine) belt for condition and tension to make sure there is no slip between the belt and the pulley. For additional information, refer to Section 303-05 .
  • Battery charge
  • Generator pulley
  • Battery junction box (BJB)Mega Fuse
  • Battery junction box fuse:
    • 11 (20A)
  • Central junction box (CJB) fuse:
    • 30 (30A)
  • Circuitry
  • Charging system warning indicator
  • Cables
  1. Check the operation of the charging system warning indicator lamp (instrument cluster). Normal operation is as follows:
    • With the ignition switch OFF, the charging system warning indicator should be OFF.
    • With the ignition switch in RUN and the engine off, the charging system warning indicator light should be on.
    • With the engine running, the charging system warning indicator light should be off.
  1. Verify the battery condition. Refer to Section 414-01 .
Normal Charging System Voltages and Charging System Warning Indicator Operation Ignition Switch Position A Circuit 35 (OG/LB) S Circuit 4 (WH/BK) I Circuit 904 (LG/RD) Generator B+ Circuit 38 (BK/OG) Battery Engine to Battery Ground Charging System Warning Indicator Operation OFF 12 volts 0 volts 0 volts 12 volts 12 volts 0 volts Off RUN-engine off 12 volts 0 volts 1-3 volts 12 volts 12 volts 0 volts Illuminated RUN-engine running 13-
15 volts 1/2 battery voltage 13-
15 volts 13-
15 volts 13-
15 volts 0 volts Off
  1. If the customer concern is verified after the initial inspection, refer to the Symptom Chart to determine which tests to carry out.
    • The charging system warning indicator is on with the engine running (the system voltage does not increase)
    • Circuitry.
    • Voltage regulator.
    • Generator.
    • GO to Pinpoint Test B .
    Your whole problem is the alternator is not charging , a couple tests with a volt meter would tell you !
2answers
Name plate states "240 Volt". Can it be rewired for 480 Volt? And how?
no,it is wired for 120 you can only run two legs to make 240.you need a different generator for that
On the 1967 sears super 12 tractor what part number replaced sears part number 606A190 for the voltage regulator
you have a starter generator... you can go to most specialty 12 volt shops ( starter re-builder ) or online and find a good quality universal V.R. can't remember if thats a 6 or 12 volt system... google 12 volt external voltage regulator and you will get an idea what I am talking about. I've done this repair a number of times
Oct 23, 2014 • Garden
On a 12 lead generator to achieve 480volts. would i have to tie 4 -7 5-8 6-9. 10 11 12 to neutral. and 1 2 3 are line leads. i can get 240 volts from my center taps, for my regulator. cause line to...
The terminals you listed are correct.
T4 -T7 mated
T5 -T8 mated
T6 -T9 mated
10, 11, 12 combined connection
L1, L2, & L3 = output / line leads
However you should have 277 VAC line to ground and 480 VAC Line to line (Across any 2 phases)
So terminals 1, 2 or 3 to ground should be 277 VAC (L1 L2 or L3)
1-2 or 1-3 = 480 VAC
any combination of
1 , 2, or 3 to each other = 480 VAC
As a "generator man" with 19 solutions one being "You might have to sting it" you should know this and be able to use the diagram on the power head to get your desired voltages unless the wiring data plate is missing. I have had to dial in voltage regulators when switching between 240 and 480 to prevent automatic shut downs from over / under voltage.
Kelly
Briggs & Stratton 12KW Model 040229 LPG Generator. 96 Volts @ the 120 Volts outlet, When I turn the house 2 Ton AC voltage increase to 106 Volts.
Can you manually adjust the voltage on the generator without load?? If you have 120/240 60hz output on it and you are not overloading the unit (amperage), then it may be as simple as adjusting whats called your gain setting for your voltage regulator. Obviously you are seeing what happens when it is set too low. Trying raising that setting until it becomes unstable then back it off. Unstable meaning voltage starts jumping all over.
Generac 5500XL, model#09778-7 no output. Changed the power regulator board. No luck. Flashed the 120 plug with 12-30vdc from DC board. Nothing. Excited the brushes directly with DC board. Only got 2.36VDC...
Double check your brush istallation. positive side toward rotor bearing, if you put 12 vdc directly into brush pack and check with a meter at the 120 vac outlet and have low or no voltage, you may have no resistance in your rotor slip rings, excitor & main windings also need a resistance check. 12.6-16.7 ohms (rotor) 2.26-2.80 ohms (excitation) .26-.32/.28-.35 main or power windings. Note: unit running when appling 12 volts to brush pack. 2-5 second only, ( This test tells you the rotor & stotor are ok )
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
