Per example, I can see well on the left side of the screen but on the right side the screen is completely black.
SOURCE: black screen on the right side of my acer 5630
You need to give me a few more details,is the screen blurry on one side,and brighter on the other?,two, are you using a some special graphics software that might not be ment for your computer,you should plug a monitor into your laptop to see if it gives the same affects,and press the window or function key, and one of the monitor symbols on your keyboard at the same time(,they are coloured the same as the function key),to change your main screen to a plug n play one,if the screen comes up with the same affects then it is a software problem,you might have to uninstall the software that is causing the problem,or two if is comes up perfectly,then it might be a hardware problem,you might have to bring your laptop to a pc mechanic to be degaussed,this puts a charge on your laptop screen and it costs more to do than replace one,most plug and play monitors can degauss them selves,others need to be done manually,unfortunately laptop screens have to be taken apart to be degaussed,i know its silly.if its not blurry then it cant be hardware problem.its one of your graphics settings.
SOURCE: P35-S605 Left side of the screen flashing
You have a crack in your LCD. You need to replace the LCD.
SOURCE: Toshiba M35 S359 Laptop screen brightness
you can try windows up date, or check the control panel, locate display and check the Brightness settings.
It is also possible that part of your screen bulb is dead, that's why one part is dimmer.
But there is no drivers that will make your screen bright.
Take care.
SOURCE: left side white. its like the whole screen has shifted to the right
The lcd convertor went out. You can get them on Ebay for a few bucks.
