Turn key to the on position and the check engine light appears when you just touch the gas pedal without raising the idle. When you start the motor at idle it does the same thing.
I found a list that might apply. Not specific to Polaris, but general for electrical. Code 021 reads accelerator fault safety lock out inspect accelerator resistance and wiring
Here's the complete list.
http://www.electricforum.com/cars/ne...ror-codes.html
Hope this gives you something to look at
I also found this list specifically for Polaris:
21 Loss of Synchronization
22 TPS Circuit: Open and Short To Ground
22 TPS Circuit: Short To Battery
23 RAM Error: Defective ECU
25 Transmission Input - Invalid Gear
26 Vehicle Speed Sensor - Implausible
41 Air Temp Sensor: Open or Short Circuit to Sensor Voltage (ECU)
41 Air Temp Sensor: Short Circuit to Ground
42 Engine Temperature Sensor Circuit: Short To Ground
42 Engine Temperature Sensor Circuit: Open or Short to Battery
45 Barometric Pressure Sensor: Circuit Low Input
46 Barometric Pressure Sensor: Circuit High Input
51 Injector 1: Open Load
51 Injector 1: Short Circuit to Ground
51 Injector 1: Short Circuit to Battery
52 Injector 2: Open Load
52 Injector 2: Short Circuit to Ground
52 Injector 2: Short Circuit to Battery
54 Engine Temperature Lamp: Open Load
54 Engine Temperature Lamp: Short Circuit to Ground
54 Engine Temperature Lamp: Short Circuit to Battery
55 Diagnostic Lamp: Open Load
55 Diagnostic Lamp: Short Circuit to Ground
55 Diagnostic Lamp: Short Circuit To Battery
56 Pump Relay Open Load
56 Pump Relay Short Circuit to Ground
56 Pump Relay Short Circuit to Battery
58 Cooling Fan: Open Load
58 Cooling Fan: Short Circuit to Ground
58 Cooling Fan: Short Circuit to Battery
61 End of Diagnostic
SOURCE: How to turn up idle on 2013 polaris sportsman 500 ho
follow ur throttle cable down to cars there should be a plastic screw close to cable to adjust idea but with polaris that screw can be hard to find with all the plasticc they put in way but if u can see carbs easy enough u will see the idle screw
Testimonial: "Thx"
