Question about Shredder Office Equipment & Supplies
Omnitech 14 sheet shredder is jammed and won't take paper less than year old tried to call omnitech support and get no answer just recording that they are closed any ideas
Posted by Mindy Tackmier on
Robert Rankin
  • 378 Answers
Unplug it, open it up and clear the jam, reassemble and give it a try, and try not to shred too many pages at once and make sure that you empty the lower part so it doesn't pick up already shredded material and jam up again.
Posted on Jul 23, 2016
2 Related Answers
Tom Chichester
  • 57296 Answers
SOURCE: omnitech 10 sheet shredder keeps running constantly after a page or pages have been completely shredded. I have to stop it and start it manually.
Shredders have to be cleaned periodically to remove bits of paper that may be blocking the sensor that detects when paper has been inserted. If you turn the shredder mechanism upside down, you can see the bits of paper and, with power off, you can pick them out. I find tweezers are a useful tool for this
Posted on Dec 13, 2012
My Omnitech 12 sheet shredder is barely 6 months old and will not even turn on.
check the warranty period and if within that period take it back for warranty repair or a new one
Dec 20, 2015 | Omnitech 12 Sheet Cross Cut Shredder
How do you removed jam paper in the schredder
1) pull what you can of the jammed paper out. Make sure the shredder is unplugged whenever trying to work on or in the unit.
2) Then liberally soak the remaining jam with shredder oil and let it sit for 15-20minutes.
3) Try to pull out what you can again. Use tweezers or pliers if available.
4) Then first start the shredder in reverse and then alternate for a few seconds between forward and reverse.
5) If it is still jammed repeat all of the steps as necessary.
Mar 09, 2015 | Omnitech 10-Sheet Micro-Cut Shredder
Shredder is jammed. Won't work.
If the shredder has power, the sheet detector may be blocked by a scrap of paper. Also, cross cut shredders that are an integral unit are best cleaned by turning them upside down to get access to the mechanism. Finally, if the motor became very hot an internal thermal fuse may have opened in which case the shredder will have to be replaced.
Dec 17, 2014 | Omnitech 12 Sheet Cross Cut Shredder
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
Omnitech shredder model ot--exc10a , shredder runs but when insert paper to shred it stops, pull out paper and it runs non stop!
Sounds like there's blockage between rollers and it also jams the sensor so auto function stops working. You will need to clear out as much jammed paper as you can using tweezers. Inspect the centre of the feed opening, there should be sensor which must be clear of blockages and moving freely. So clear any stuck paper with tweezers, in addition you can soak any jammed paper with WD-40 and unit should be good as new. Although if sensor arm is damaged then replacement of such sensor is unavoidable.
Nov 04, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
I just bought the Omnitech 10 Sheet Cross Cut Shredder. Is it safe to shred papers with staples in them?
I don't have that model but have an 8 page cheapo shredder. It takes CDs, credit cards and staples with no whining.
Oct 23, 2013 | Omnitech 12 Sheet Cross Cut Shredder
Omnitech 10 sheet shredder keeps running constantly after a page or pages have been completely shredded. I have to stop it and start it manually.
Dec 13, 2012 | Omnitech 10-Sheet Micro-Cut Shredder
1,909 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
gbob59
Marvin
Marvin
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
