Televison & Video Logo
Debbie Armstrong Posted on Jul 22, 2016
Does anyone have a region hack code for Bush CDVD100W1SWM portable DVD player?
Peter James Ledwith
Level 1:
  • Contributor 1 Answer
  • Posted on May 26, 2019
Peter James Ledwith
Contributor
Level 1:
Answers
Questions
0
Helped
454
Points
0
None of these works on this player.
5 Related Answers
Anonymous
  • Posted on Dec 06, 2009
SOURCE: Region hack needed for GPX PD907B DVD Player
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
Anonymous
  • Posted on Mar 30, 2008
SOURCE: Unlock region code
I found this info on the site and it works!!!!
1. Switch on the DVD player.
2. Open the disc tray, and leave it open.
3. On your remote key in the following number: 81328
4. Then press the ENTER key a number of times till region 9 comes up.
5. Press the MENU button on your remote.
6. Finally close the tray.
Anonymous
  • Posted on May 20, 2008
SOURCE: 7" LG Portable DVD Player DP271
Hi
I have tried to unlock the DVD DP271 player using following methods, But it is not unlocking. If any body knows any other code. Please help me to un lock my DVD DP271 player.
Thanks
Sekahr
1. Power up and press setup
2 Scroll down to LOCK
3 Press '0' (zero) seven times
4. A message may now appear with saying that the player is region free.
5. Power down then power up.
or
1. Remove any discs and power up the DVD
2. Press PAUSE
3. Enter 314159
4. The hidden region code menu may now appear.
5. Set code you want- 0 for multiregion, 1 for region 1 and so on
6. Press PAUSE
7. Power down then power up
Anonymous
  • Posted on Jul 06, 2008
SOURCE: region code
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
jaffa012001
L Jefferson
  • 376 Answers
  • Posted on Aug 29, 2008
SOURCE: Hi i need to find
1. Open the DVD cover
2. Press setup
3. Type 9 6 5 3
4. Press the Arrow Key up or down and select 0 for region free
5. Hit OK
2answers
What is the unlock code/region hack for a Bush 12" portable DVD player? The model is CDVD12SWM.
Give this a run
Make Your DVD Player Region Free in Seconds
  1. Power on.
  2. Open tray.
  3. Push the info on remote once (with supplied remote). You will see numbers.
  4. Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
  5. Power off.
  6. Power on.
Multi region code for bush cdvd3601hdmi dvd player?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Region code hack procedure to many popular devices are given.
1helpful
2answers
Bush dvd 3081 region code
Bush / Curtis 3081
1) Open drive
2) Enter 9999
3) Enter 0 (for region free)
2helpful
2answers
What is the hack code for a bush cdvd90w2sw portable dvd player
Hi, I found this thread because I was looking for this same hack to play the DVD's my kids bought in the States on my UK sourced player. None of the above worked so I tried looking for hacks for other budget brands. As luck would have it the first one I came across for a Wal Mart portable DVD worked first time. Here it is...
•Turn on the power
•Open the lid
•Push the following number sequence on the remote control:
•9 7 3 5
•Use your arrow keys to select '0' for all regions
•Exit setup
Worked instantly.
2answers
How to make Sony portable DVD player DVP-FX810 region free
Do a google search for 'region hack and your model #' Not all players can be hacked and don'y pay anyone for the info. Usually a scam.
2helpful
4answers
Unlock region codes
Hi All,
I am looking for the region unlock code for a Sony portable
DVD player.Model number DVP-FX720
Top Bush Televison & Video Experts
matt martin
matt martin
Sean Wright
Sean Wright
john h
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
