Washing Machines Logo
A
Anonymous Posted on Jul 22, 2016
My washing machine singer model WT5416, wants I on power there appear error code E9 what's a problem
  • Rudy Musafir
    Rudy Musafir Mar 29, 2019
    My washing machine singer model WT5416,ERROR CODE E7 WHAT PROBLEM
  • yaty mamat Jul 16, 2019
    door lock
Wan Syafiq
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 02, 2021
Wan Syafiq
Contributor
Level 1:
Answers
Questions
0
Helped
2606
Points
My washing machine singer model WT5416,ERROR CODE 1E WHAT PROBLEM
Rudy Musafir
Level 1:
  • Posted on Mar 29, 2019
Rudy Musafir
Contributor
Level 1:
Answers
Questions
Helped
2606
Points
Washing machine wt 5416 are code E7
Vivek Pandora
Level 1:
Habit-Forming:
New Friend:
  • Contributor 15 Answers
  • Posted on Jul 23, 2016
Vivek Pandora
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
15
Questions
Helped
23228
Points
27
E9 error indicates there is an issue with pressure sensor switch
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Jun 25, 2008
SOURCE: E9 error means what
there is an error no 9
Anonymous
  • Posted on Aug 16, 2008
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Anonymous
  • 373 Answers
  • Posted on Jan 11, 2009
SOURCE: dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Anonymous
  • Posted on Jan 27, 2009
SOURCE: My NEC NW 652 washing machine is showing an E9 fault
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Anonymous
  • 15935 Answers
  • Posted on Sep 16, 2010
SOURCE: got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
How to fix E9 washing machine error please? Once I start the machine it shows E9. How to fix the fault?
All question need full 'make model (what it is)', first 3 words please.
Here are all the Washing Machine E9 Errors by maker.
https://www.google.com/search?q=E9+washing+machine+error
My Washing Machine Daewoo DWF 200P Displayed ( E9 ) in screen
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
Daewoo Washing Machine Error Fault Codes
https://removeandreplace.com > 2015/11/02 > daewoo-...
Nov. 2, 2015 - The Daewoo generalized error fault codes below are to give you an "idea" as to what part is at fault. ... Daewoo Washing Machine Error Fault Code = E9 ... If your Daewoo Washing Machine Error Code is not listed here, check ... Mine is Daewoo washing machine DWF-8288, showing E1 and won't spin and ...
Hi The spilt had error E9 ... What I can do for fixing?
What manufacturer and model washing machine is it?
What event occurs before the error E9 appears?
E9 DISPLAYED IN WASHING MACHINE DAEOO MODEL DWF320LR WHAT IS THE PROBLEM
Error Code E9 for Kelvinator KL15TL washing machine. How can I fix it myself?
My search came up with "low pressure sensor error". Theoretically you could replace this sensor yourself but it will depend if you will be able to ensure you do not damage the port it screws into and it doesn't subsequently leak. Found a link with an image of the different types of sensor units in it -
have Kelvinator model KSV80HRA showing an E9 error code
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
73helpful
7answers
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
4helpful
Dwd f1011 washing machine, error codes E2&E9, machine not working
1helpful
4answers
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Top Washing Machines Experts
john h
