This car was built in belgium and has an opel ecotec engine Z18xe or Z18xer the car is like the astra H 2005-2010 GM imported the cars from Belgium with the ecotec 1.8 litre engine the yellow oil filler cap is on the right hand side of the engine cover
So what is the problem? The new filter for a Z18XE screws directly on to the front of the engine block behind the radiator, and the oil drains out of the drain plug at the base of the sump. The Z18XER only differs in that the filter sits in a round black housing visible from the top right of the engine and is requires a 32mm spanner to remove the cover. The filter is different from that on the Z18XE
SOURCE: Our holden/vauxhall/opel astra 2001 model
opel astra ,which is marketed as vauxhall or holden ,also dawoo .right now what i need to know is and as a woman you have ommited to state, is it a manual or a automatic gearbox ,now remember the time zone difference iam in spain and you in vegamite land .Where my son is and i want to visit .
SOURCE: opel astra 2006 car engine made but it doesent
Check starter and battery charge? Its possible that you have THEFT security system armed? Check owners manual to disarm procedure.
Finally, check ignition swtcih:
Keep us updated.
if the heaters hot and not blowing cold then no problem
