? 7:02 www.youtube.com/watch?v=gVXT7pZyk_o Sep 12, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Upright Freezer which has the following problems: Not Cooling Properly At: http ...
www.realestate.com > Realestate.com Blog > Articles Aug 12, 2012 - Alternatively, if the freezer is in a defrost cycle, it will not kick on immediately, the temperature ... Refrigerant circulates through coils, spreading coldthrough the unit interior before .... We have a kenmore upright deep freezer.
Hi
I think the problem you are experiencing might be due to the temperature control.
1. Check if the temperature control is off if you dont hear the freezer operating.
2.If you do not see an interior light,when you open the door,then make sure the freezer is properly plugged into an electrical outlet.
3.Move the temperature level to a colder level if the freezer is not cold enough.Warm weather can also be a factor.
4.Find the condenser and check to see if it needs to be cleaned. The condenser is located behind the decorative paneling at the bottom of the freezer.
5.If it doesnt work still then contact a technician.
GOODLUCK
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
You Said, I have a Whirlpool upright freezer AFG 371/H there is a digital display
and lights and buttons, on/off temp alarm etc running across the top of
the freezer. None of this works but the freezer is still freezing. i
have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
