Aunt died and I received a vintage necchi machine in a coronet cabinet with all attachments. where do I find the model number or how do I tell exactly what machine version I inherited?Serv.no 64809/spec no 915
Manufacturers put the numbers anywhere on the machine. Often, they can be found under the machine and may be a plate but often are numbers stamped into the metal. It may be on the metal base and could be hidden by the cabinet. However, if it is like some older Singers, there were no model numbers on the machines. The serial number actually signifies the model, ie N-6001-N-21000 is a Model 15.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwjohsLMlYXOAhWn6YMKHUcCC_kQFggwMAM&url=http%3A%2F%2Ffreenecchisewingmachinefiles.weebly.com%2Fuploads%2F1%2F8%2F7%2F3%2F18731174%2Fnecchi_model_list.pdf&usg=AFQjCNGMnPd8ffPJCeXrazqOj2oo-hsC7A&cad=rja
Vintage Sewing Machines
You could also take the machine to a sewing repair shop. Some of the older shop technicians are probably more familiar with these machines.
SOURCE: Necchi machine
Bu Mira was made in Italy between 1952-1956 it was the machine where the introduced the Wonder Wheel to make decorative stitches, olive green in color . There are some people who collect them but like all antiques the rearer the are and the better origonal condition the are in the more the are worth.
SOURCE: making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
SOURCE: manual fornecchi-alco sewing machine model 301
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
SOURCE: How do I thread my necchi Lydia type 544 sewing machine
Threading guide - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_542_544_threading_Diagram.htm
Make sure the presser foot is up when threading any sewing machine.
SOURCE: Recently inherited a Necchi sewing machine Model
i have a Necchi 523 instruction manual> you may email me at [email protected] put sewing machine in the subject line...Denise
Hi Michele Did you look on the bottom of the machine.
