How to change belts on Keystone K108 8mm movie projector.
How to change belts in Keystone K108 8mm projector. I have been using the projector in a digitizing project with no problems at all. It suddenly stopped both reels' movement without a sound while the motor and lamp continued normally. The clutch and the other 2 levers were in proper positions. Only last week I had lubed all 7 marked oil ports with watch oil. My problem is that I cannot disassemble it for further inspection. I have removed all visible screws that retain the motor and it's housing and shields but it seems to be obstructed in the area of the front motor shaft. Inadequate movement of the loosened covers prevent observing just what is holding it. The loosened cover moves perhaps 1/4 in all directions but no more. I strongly suspect disassembly will have to be completed before I can get it back together! Thanks for any help or advice!! Denny
Posted by Denzil Cypret on
Ron Durham
    Master:
  • 508 Answers
I strongly suspect a broken belt the covers need to come off.
Posted on Jul 21, 2016
Testimonial: "THANKS VERY MUCH, RON. THAT HAS BEEN MY IMPRESSION ALL ALONG. FINALLY GOT IT APART-REMOVED THE BRUSH ASSMBY FROM MOTOR; ALL EXPOSED! TOP BELT STRETCHED(?) BUT SLIPPING. HAS SPRING LOADED CLUTCH THERE TO DRIVE FINAL GEAR. IT CLEARLY IS ANTI-FILM-BREAK FEATURE. WILL ADJUST IT OH SO CAREFULLY AND REPLACE BOTH BELTS AND CROSS FINGERS! NOW TO GET IT BACK TOGETHER AGAIN--MANY GEARS, SPRINGS, SCREWS, GEARED SHAFTS, MEH! THANKS AGAIN! DENNY PS-YOU DON'T HAVE AN EXPLODED PARTS DIAGRAM DO YOU? (INAPPROPRIATE GIGGLE!)"
5 Related Answers
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: not spinning
OK, if the motor is spinning but not turning the clutch hub, that means the transmission is jammed. You may be able to free it by manually turning the big pulley on the bottom of the transmissiion, but the problem will reoccur. The real solution would be to replace the transmission assembley in this case. (Transmission WH38X1002) Check the last pages of your users manual for warranty info. Warranty will vary based on model and date of manufacture. Typically, transmissions will have a 5 years part only warranty.
Posted on Aug 28, 2008
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: How easy to access the 3 screws?
Underneath. Don't see original post here, but to replace a pump (actually, just the pump motor) on an LG front load washer: Drain water out of small hose inside recess and remove access door cover (at lower left of machine). Remove one phillips head screw and use a plastic putty knife or similar tool to push in on left or right side of recess to remove the plastic recess cup. Now remove the two other phillips head screws visible. Tilt machine back and access pump Assembly from under machine. There is a tab that you will have to work loose. Disconnect electrical wires from pump at disconnect plug. You probably want to remove the hoses going to and away from the pump (squeeze clamps). Pump motor is easy to change out now with three more phillips head screws.
Posted on Sep 02, 2008
Anonymous
SOURCE: Ball Bearing Replacement
when spinning , it is noisy. How to overcome it.
Posted on Nov 25, 2008
Anonymous
  • 1937 Answers
SOURCE: removing the clutch from the transmission shaft
Please see the following (in particular page 10)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The E-clip is sometimes a bear to remove and a real pain to re-install.
There is a washer above the E-clip.
Please see again the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Posted on Oct 29, 2009
TheMobilian
Dan Webster
  • 8221 Answers
SOURCE: Water dripping from right (as
Remove the rear screws on the top on most models.Then slide is back and lift it off.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 22, 2011
I have a Keystone K75. The film will not stay in a loop after going through projector so it goes through too fast and you cannot watch the movie. Any ideas of what is wrong?
When threading the projector you must have a loop of film before and after the film gate (the part that swings open). You can also try turning the projector on with no film in it and make sure both upper and lower sprockets are turning. If this is a new problem you might have a broken belt or gear inside. Take it to a camera repair shop and they can tell you more.
Jan 05, 2015 | Office Equipment & Supplies
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
How do I adjust for Keystone on polaview 340 projector?
There is a menu accesible also from the buttons and you can change it there.
Jun 04, 2014 | Polaroid Lamp for POLAVIEW 340 Projector
How do you change the lamp in a mod # 980Z keystone projector
There is a black and silver knob under the keystone label( right above the automatic label ) on the side of your projector. turn this knob counterclockwise to loosen the covering over the housing unit for the lamb. once the knob is loosened lift the housing unit off of the side of the projector. You wlll see the enclosure where the lamp fits into beneath it.
Make sure the power is off for your projector while doing so. Screw the lamb into the enclosure , then replace the covering and screw the black knob in clockwise until it tightens.
Sep 21, 2012 | Office Equipment & Supplies
I cant figure out how to work this movie projector i cant get the movie to load and play on the screen. I have hundreds of old movies to watch. the projector is a keystone k100
Old film projectors are sometimes challenging to operate.
I have an old Bell&Howell and have to stop and think whenever a friend asks me to transfer a film to DVD. (Fortunately not often anymore.)
I just Googled keystone k100 and got several sites including several videos on Youtube.
I'm sure you'll find something in your flavour.
Good luck! Have fun.
Jun 16, 2011 | Cameras
The projector comes on.but there is no picture.lens not opening
Press and hold the two Keystone buttons on the top of the projector. Turn the projector ON and continue to hold down the two Keystone buttons for 15 seconds.
Release the Keystone buttons.
Turn OFF projector.
Turn ON projector, lamp should strike.
Sep 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
Keystone 8mm movie projector
Re Keystone 68 projectors:
I join the growing throngs of folks who wish to view their family archives in 8 mm before submitting the reels to the digitals for conversion. Doesn't anyone have an answer for us? I continue to search, if I find, I'll post.
Fauvette
Jul 12, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Keystone movie projector
there should be a belt inside that transfers rotational power to the gear train. the belt may be a long spring type of belt.
Nov 29, 2007 | Photography
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
