Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro Logo
Tim Saucier Posted on Jul 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connecting t103 timer to a 120 volt gfci - Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro
J.D. Browning
Level 3:
  • Master 2,760 Answers
  • Posted on Jul 20, 2016
J.D. Browning
Master
Level 3:
Answers
2760
Questions
0
Helped
1015030
Points
6696
That should work no problem , but do make sure its only a gfci model not a combo acfi/gfci as with a mechanical timer the acfi is gonna misinterpret the switch closure and shut the power off
ohh and do remember just because the timer is rated at 40 amps and your feeding it with a 20 amp gfci doesn't mean it will work too 40 amps !!
tip
How to wire Intermatic T103 and T104 timers
VERY IMPORTANT: Understand that in US residential wiring the WHITE wire is _NOT_ ALWAYS_ the neutral wire. Additionally, prior to 1999 the National Electric Code (NEC) did not require that these white wires be re-identified with black tape or similar means when used for purposes other than neutral. The white wire is sometimes used as a hot, especially when wiring Intermatic T103 and T104 timers.
Also understand that the WHITE neutral wire and the bare (or green) equipment grounding wire are connected together ONLY at the main electric power panel and must _never_be connected together _again_. Once those two wires leave the main electric panel, the WHITE neutral wire must _always_ remain insulated from the bare or green equipment grounding wire. This is very important for safety considerations.
If your wiring is very old and does not have a bare equipment grounding conductor, you _must_ protect the circuit with a GFCI (Ground Fault Circuit Interupter). GFCI wiring is not difficult but is beyond the scope of this post.
DETERMINE WHAT CABLE YOU HAVE:
Usually one will find one of the three following scenarios for the incoming supply cables when wiring a T103 or T104 Intermatic timer:
1...A 120 volt cable with 3 wires: black, white, and bare. The black is LINE (hot), white is neutral and bare is equipment grounding. Black to white is 120 volts. This scenario can be used with the T103, but not the T104.
2...A 240 volt cable with 3 wires: black, white, and bare. The black is LINE(hot), the WHITE is LINE (HOT), and the bare is equipment grounding. Black to white is 240 volts. This scenario is used with the T104 ONLY.
3...A 120/240 volt cable with 4 wires: Black, red, white, and bare. The black and red are (LINE) hot, white is neutral and bare is equipment grounding. Black to red is 240 volts. Black to white is 120 volts. Red to white is 120 volts. This scenario can be used with either the T103 or the T104.
The only difference between the T103 and the T104 is the timer motor voltage rating. The T103 uses a 120 volt timer motor and the T104 uses a 240 volt timer motor. The T103 timer motor is connected to terminal "A" and terminal #3 during manufacturing. The T104 timer motor is connected to terminal #1 and terminal 3# at the factory.
Also, when connecting the bare or green wires to the "GR" terminal, it is best to wirenut the wires together with a pigtail, then connect the pigtail to the "GR" (GRound) terminal, WHICH IS THE GREEN SCREW ON THE LOWER PART OF THE CASE.
WIRING THE TIMER:
The wiring diagram for the T103 is here:
http://www.progressive-growth.com/wiring/T103.pdf
___________________________________________________________________
WIRING THE T103 USING AN INCOMING 120/240 VOLT CABLE WITH 4 WIRES (scenario #3):
Incoming (LINE) wires from 240 volt circuit breaker:
Connect the black (LINE)(hot) wire to terminal #1. Connect the red (LINE) (hot) wire to terminal #3. Connect the white (neutral in this case) wire to terminal "A".
Connect the bare equipment grounding wire to the "GR" terminal, which is the green screw on the case.
Outgoing wires to 240 volt load:
Connect one (hot) wire to terminal #2 and the other (hot) wire to terminal #4. The bare or green wire goes to the "GR" terminal.
WIRING THE T103 USING AN INCOMING _120_ VOLT CABLE WITH 3 WIRES (scenario #1):
Incoming wires from 120 volt breaker or source:
Black (LINE) to terminal #3. White (neutral) to terminal "A". Bare to the "GR" terminal.
Terminals #1 and #2 are NOT used in this case.
Outgoing wires to 120 volt load(s):
Black(hot) to terminal #4. White(neutral) to terminal "A". Bare to the "GR" terminal.
The wiring diagram for the T104 is here:
http://www.progressive-growth.com/wiring/T104.pdf
WIRING THE T104 USING AN INCOMING 240 VOLT CABLE WITH 3 WIRES (scenario #2):
Incoming (LINE) wires from breaker:
Connect the black (LINE) (hot) wire to terminal #1. Connect the white (LINE) (hot in this case) to terminal #3. Connect the bare wire to the "GR" terminal.
The "A" terminal is _NOT_ used.
Outgoing wires to load:
Connect one (hot) wire to terminal #2 and the other (hot) wire to terminal #4. Connect the bare or green wire to terminal "GR".
WIRING THE T104 USING AN INCOMING 240 VOLT CABLE WITH 4 WIRES:
Same as above, except the white wire is not used. Just tape or wirenut it off.
Comment by gotgeek2, posted on Jan 08, 2010ckuzkuz, I'm a licensed master electrician in 2 states with 30 years in the trade. I've installed a lot of Intermatic timers over the years. I wrote this tip because I saw that a lot of folks were having problems wiring them.
on Mar 07, 2010 • Garden
tip
These instructions are for USA residential wiring only.
WIRING THE TIMER:
What kind of charger do a t103 use
T103 timer is operated with 120Volt AC power.
Open following link to identify correct wiring and identify timer.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
My Intermatic T103 Indoor 120-Volt 40-amp timer emits a constant peeping sound
Intermatic T103 is mechanical timer with moving gears.
Timer makes audible sound when tripper clicks on-off, but it should not make constant noise unless gears are causing noise.
Turn off power and spray WD-40 on gears and see if problem continues.
WD-40 vapor is extremely flammable hydrocarbon when sprayed, and should not be sprayed on live electric circuits.
If problem continues, turn off power, pull mechanism out and spray WD-40 on plastic gears of clock motor.
Open following links for illustrations of clock motor and removing mechanism.
http://waterheatertimer.org/images/WH40-005-gears-350.jpg
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
I have an Intermatic T103 DPST timer installed now (120v). The clock mechanism has failed. I bought Tork 1103 guts to replace it. The wiring is a bit different. Can u map for me which wires go to which...
T-103 has 120V clock motor with 5 terminals A 1 2 3 4
Tork 1101 has 120V clock motor with 4 terminals L 1 X 2
T103 is DPST and can control one-or-two 120Volt loads, or one-or-two 240Volt loads.
Tork 1101 is SPST can control one 120Volt load
Common ground between these timers one 120 Volt load
Changeover for one 120 Volt load:
White wires T103 terminal A go to Tork terminal X
Black wire T103 terminal 1 goes Tork terminals L and 1 (there is brass connector plate that connects L and 1 - if connector is missing, jumper between L and 1)
Black wire on T103 terminal 2 goes Tork terminal 2
If Load requirement is greater than T1101, Grainger sells T103 clock motor for $16
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T103
T1101 wiring manual
http://waterheatertimer.org/pdf/110111021103WIRING.pdf
1helpful
2answers
Circuit breaker keeps tripping when timer turns on. Also, if turned on manually.Intermatic T103. I've had this timer for about a year and everything was fine until now.
Internal components of manual electrical timers do wear out (in my case, within 2 years), which will trip an AFCI/GFCI breaker at the same time every day, even before the circuit switches on. This regularity of the problem (at 5:50 PM every day) was the clue that the timer was at fault.
1helpful
T103 clock not working
Please read all of this post. You may burn up the 120 volt T103 timer motor is you are not careful.
The statement: "I have 120v board with 120 constant and 240 timed" is not very clear to me as to what you mean.
In US residential wiring, the white wire is not always the "neutral;" The white wire is sometimes used for 240 volt circuits.
We cannot tell you how to wire your timer unless we know _exactly_ what you have.
If your incoming supply cable (from the breaker box) has 3 wires (black, white, and bare), there are two scenarios:
1...If the voltage from black (hot) to white (ALSO hot in this case) is 240 volts, and you have only 3 wires (black, white, and bare), then the T103 is the _wrong_ timer if you are trying to control a 240 volt load. You should use a T104 timer.
The T104 uses a 240 volt timer motor and the T103 uses a 120 volt timer motor.
2...If the voltage between black and white is 120 volts, then you will only be able to control 120 volt loads; then the incoming black supply wire is connected to terminal 3 and the white (neutral) wire is connected to the "A" terminal. The bare equipment grounding wire is then connected to the "GR" terminal.
To show the difference, if you are trying to control a 240 volt load, to use a T103 and wire it _correctly_, you would need to have a incoming supply cable with a total of 4 wires (black, red, white (neutral), and bare) Black to red would be 240 volts. Black to white would be 120 volts. Red to white would be 120 volts.
The connections would be as follows:
White (neutral in this case) to the "A" terminal
Black to terminal 1
Red to terminal 3
The 240 volt load would then connect to terminals 2 and 4
Both the bare equipment grounding wires are connected to the "GR" terminal.
Since you did not mention a red wire, I can only ASSUME that this is not the case.
Sorry, we can't tell you how to wire this timer based upon assumptions.
So, what do you have?
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
