Question about Lenovo Computers & Internet
Why on desktop pc,W10. can I save data,to flash card,and CD, then remove above items, and add more data to pc then replace items and added data is already on them, withou being saved?
The items can be removed en masse or one by one and replaced the same but the added data is still on the storage without me saving it to them ? Grrr
Posted by dadllo on
  • Marvin
    Marvin Jul 18, 2016
    Hi dadllo , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • dadllo
    dadllo Jul 18, 2016
    Ok, I need to save some data, which is quite detailed. Having lost the data once I had to go back weeks to repair the lost material. So, now I store just that data on a flash drive, a CD and an SD card,, It is also stored on an external hard disk.So each day when I add data, I only save it on the hard disk and in docs,but when I insert either of the units above they read the same as the saved data, but they were removed before I saved them, so how could that extra data, be on them?
5 Related Answers
Kawika-56
David Lagesse
  • 233 Answers
SOURCE: Adding data file to existing CD-RW disc in Roxio
First off, for your information your Roxio is OLD, they now have Roxio 9.
But that will not solve your problem. Can you open the CD and copy and paste anything? Or is the CD "Read Only"? If read only, it is because when you "Finalized" the CD you optioned the "Write Protect" making writing to the disk impossible. This protects the disk from erasure too.
You will need to use another disk.
Otherwise you can just use the same method you used before to write to the disk, or Copy and Paste, or Drag and Drop.
The Write Protect is specific to the program you are running.
However, Roxio 7 and 9 program I have used ask, "Do you want to be able to write to this disk again?" or words to that effect. All you need to do is just put a check in the box (or not, if you want to write to disk again). This happens when you are ready to remove the CD or DVD from the drive. Then the program runs a "Finalizing" program before the disk automatically ejects.
Posted on Nov 15, 2007
Anonymous
  • 32 Answers
SOURCE: my quickbooks pro 2007 won't do the back-up at all
If you have the original cd you may need it to restore some defective, altered or missing files. You can begin by going into Control Panel, Add/Remove (assuming XP) and Selecting Quickbooks. If you see an option to repair the program, select it and proceed.
Alternative option is to reinstall the CD and launch the setup. It will ask you is you want to repair the installation. Agree to this choice and proceed.
Once the repair is complete, restart the program and see if the problem is rectified. Good luck.
Posted on Jan 21, 2009
Anonymous
SOURCE: data saving problem in samsung omnia i900.
i have problem with samsung omnia. i can't receive data via bluetooth. i turn on bluetooth and find device but i can't receive data from other phones or computers... please help
Posted on Jun 11, 2009
Anonymous
SOURCE: My Playstation 2 memory card has corrupted data.
well, if it only does this error for one game then maybe the problem is in the game itself? Is the CD a real one? or is it copied with a golden back?
if it is copied then such things can definitely happen.
Posted on Jul 21, 2009
Anonymous
SOURCE: Using the USB cable I connected my HP Simplesave
Be sure you close any program that has accessed the drive.
Posted on Jan 12, 2010
Why when my desktop crashed,why did I also lose data stored om my Flash drve, cd and sd card?
You can't lose data stored on a CD because your desktop crashed as long as it wasn't being written to at that exact moment. And unless your Flash drive and SD card were plugged in at that moment, they shouldn't have lost data either! Even if they were, they shouldn't lose data unless being written to at the time.
Or are you using some kind of weird encryption on your whole system?
Jul 20, 2016 | Lenovo Computers & Internet
I inadvertently used a search engine ASK to download some irs files. Now can't get rid of it. It has taken over firefox.
https://support.mozilla.org/en-US/kb/refresh-firefox-reset-add-ons-and-settings
What does the refresh feature do? All of your Firefox settings and personal information are stored in a profile folder. The refresh feature works by creating a new profile folder for you while saving your important data.
Add-ons which are normally stored inside the Firefox profile folder, such as extensions and themes, will be removed. Add-ons stored in other locations, such as plugins, will not be removed but any modified preferences (such as plugins you have disabled) will be reset.
Firefox will save these items:
  • Bookmarks
  • Browsing history
  • Passwords
  • Open windows, tabs and tab groups
  • Cookies
  • Web form auto-fill information
  • Personal dictionary
These items and settings will be removed: Note: Your old Firefox profile will be placed on your desktop in a folder named "Old Firefox Data". If the refresh didn't fix your problem you can restore some of the information not saved by copying files to the new profile that was created. If you don't need this folder any longer, you should delete it as it contains sensitive information.
Feb 24, 2016 | Apple MacBook Pro Laptop Computer with...
I inadvertently downloaded a search engine asK while attempting to access IRS files. Now it has taken over firefox
  • Bookmarks
  • Browsing history
  • Passwords
  • Cookies
Memory card unlocker
Micro SD (secure data) cards store information such as Word, image and video files.
Kingston microSD cards are used in many settings, such as schools, businesses and government offices, to protect data.
Some Kingston microSD cards are locked for added protection.
In the locked position, you cannot add or delete data from a microSD card.
You will need to unlock your Kingston microSD card in order to save data on it or delete data from it.
Remove the Kingston microSD card from whatever device it is kept in, whether it's a storage case, a digital camera or a GPS.
Find the small plastic switch on your Kingston microSD card.
If you are looking at the microSD card with the arrow pointing away from you, the switch will be on the right side of the card.
Flip the switch on the card to the unlocked position.
This will enable you to store and remove files on your Kingston microSD card.
http://www.kingston.com/flash/securedigital.asp
Jan 24, 2012 | Kingston 1 GB microSD Card with USB 20...
I need help to save the data on my pc and restore it back to the day i bought it
You can save your data to an external hard drive or save it to a flash drive, CD, DVD, or any other removable device.
Jan 28, 2011 | HP Computers & Internet
Sd card is detected but cant open
I find that the easiest place to find files on a HDD or SD card that i connect but the drive comes up is by going right click on computer and going to the manage option.
I then go down to disk management and look for the storage that I have added.
Then right click on "change drive letter and path" and add give the storage a drive letter
For some reason the computer sometimes does not complete this part which leaves the drive unreadable
It is always a good thing to do to go to device drivers to check that you can see the drivers for the device being installed. This can be achieved by removing and replacing the storage device while device manager is open
May 26, 2010 | SanDisk 2GB microSD Memory Card
When computer isturned on the keyboard status lights are all on with the light with the number 9 in it is flashing
That sequence of lights indicates a motherboard failure. Remove all drives, RAM, Battery and Wireless cards, see if LED indications change, if they do add 1 RAM module back and see if system will POST. If it does, keep adding items till the faulty item is ID'd. If LEDs do not change, or still no POST with any RAM module, replace the motherboard
Nov 04, 2009 | Dell Vostro 1510 Laptop
I want to upgrade Compaq Presario SR5410F with Video card GE FORCE 8600GT, 512 mb. What are the requirements of DDR Memory (Presently 1GIG AND Power Supply 200Watts). Please explain what to add and take...
To install the 8600GT, turn off your computer, unplug the power cable going to your power supply, remove the side panel of your case, remove the current video card and firmly push the 8600GT into your PCI-Express x16 slot. Now plug in your monitor to the video card’s ports, close up your case, plug in your power cable, and turn on your machine. In BIOS turn off the built-in video and enable the PCIe slot for use. Restart. Insert the included installation CD and follow the onscreen instructions. The power supply is small but should work as long as you have not added other items. The memory is adequate and does not matter as far as adding a video card is concerned. Some games may require more memory, however.
Oct 20, 2008 | Compaq Computers & Internet
Pcv-w10
you can make a recovery cd with your computer..does it run at all?
Mar 23, 2008 | Sony VAIO PCV-W10 PC Desktop
Computers & Internet Logo
71 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
