Question about Audio Technica Audio Players & Recorders
Audio technica at 120 cartridge will fit my project essential?
I have pro ject essential turntable with ortofon om 5e cartridge,i would like to replace it with audio technica AT 120 cartridge but i don.t know if it will fit?
  • Audio Technica Master
  • 5,699 Answers
Having looked at the turntable it seems to mount the cartridge with two bolt like fittings. The Cartridge you want has two mounts on the side that will take those bolts.
You will have to adjust the arm to compensate for the weight differences between the two cartridges, but once done it should play fine.
Posted on Jul 28, 2016
Hi. i have a audio technica atn91 cartridge for it and want to know the tracking force and the counterweight i should set?
I have used this article to set up my dual turntable.
Cartridge Alignment The Basics Explained
Tracking force: 1.5 to 2.5g
Your cartridge specifications are in the following link.
Audio Technica AT91
Hope this helps?
Mar 23, 2016 | Audio Technica Audio Players & Recorders
I bought an Audio Technica USB AT LP 120 Turntable last June. It worked fine as a turntable, but I was never able to get good recordings of vinyl without distortion. But now I have another problem: when...
Sorry it could be the cartridge! They can fail at anytime, only the stylus will wear with time. However it could be the amplifer's magnetic cartridge pre-amp. If you look inside your amp and trace back from the phono socket you should find the pre-amp. If it is distorting on both channels it's probably an IC that has failed.
Dec 05, 2010 | Audio Technica USB Turntable
Need replacement cartridge & Stylus
dont know about New Zealand but you could contact this company and mail order it/ship it to N/Z?
mailto:[email protected]
Sep 27, 2009 | Audio Players & Recorders
Turntable skips during playback
The only thing I can say is to make sure you set up your cartridges correctly - click HERE FOR INSTRUCTIONS on BALANCING YOUR TONEARM properly.
If, you've balanced your tonearm, and set up your cartridges correctly, then you should not have any problems. Unless, your tonearms are damaged. But this is highly unlikely. I just think you need to balance properly.
Another note, Ortofon Concorde have a design flaw, in that they don't connect very well to the Technics tonearm. The Concorde's, have short and stubby connections on the rear, making for poor connections to the tonearm. Ortofon has addressed this issue by releasing the Ortofon OM series cartridges, and mount them to standard Technics Headshell.
If you still can't figure this out, feel free to give our techs a call 24/7 @ 1.866.668.1596 ext 1 - they can walk you through setting up, and properly testing your tonearm to see if it's damaged or not.
- DJ PRO LAB
www.DJPROLAB.com
May 12, 2008 | Technics SL-1200MK2 Turntable
New needle for sony ps-lx250h?
Yes It's possible.You can purchase it on amazon, click here and take a look: Amazon com sony ps lx250h needle. I hope this was helpful. Cheers
Jan 24, 2008 | Sony PS-LX250H Turntable
279 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
