Hey, anything is possible! Even I have baked a cake in one. Use Panasonic's cook book, or something else from a wonderful author like Betty Crocker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
SOURCE: method of baking a cake in Microwave
I hv got a ifb microwave oven 23sci with powergrill and i have tried baking cakes half a dozen time and every time it gets burnt. The sides get baked and the central zone is unbaked. MY method is , I take a glass utensil and put the cake mixture into it and put the same into the ifb oven, then i select the microve+conventional mode (200*) and bake it for 12 minutes. Can u guide me so that my cakes have a better future hence forth.
SOURCE: my microwave oven manual has lost,i want to
You can get the manual on the link below. Please give it time to load it is a large file.
http://www.panasonic.ae/EN/Manuals/NN-G335WF.pdf
Good Luck and please rate 4 thumbs up for the free answer
SOURCE: Can you please send me
http://panasonic.ru/upload/iblock/f53/NN-G335M_NN-G335W_NN-G335B_NN-G315W.pdf
GO TO THIS SITE AND THEY WILL HAVE YOUR MANUAL AT NO CHARGE, YOU MUST HAVE PDF ON YOUR COMPUTER
SOURCE: Panasonic 28 L NN C784
hi,
look in the back through the grille with a flashlight to see if the cooling fan is running, you should feel a slight draft there too. if not running take the cover off and oil the magnetron cooling fan with 3 in1 sewing machine oil. oil it on both sides of the motor so its saturated. if it does it again you will have to order that motor. probably at panasonic.com or searspartsdirect.com. be careful inside the microwave with the cover off, avoid the red high voltage wires. use gloves if necessary. panasonics are a pretty good oven, worth fixing..
jm
