Question about Fisher and Paykel Washing Machines
How to clean drum in fisher paykel washing machine ? Also why so noisy and moving across floor on spin cycle?
Have hand cleaned and washed out all wash powders
Posted by Paula gray on
Bill Boyd
    Top Expert:
  • Fisher and P... Master
  • 53,816 Answers
Bowl out of balance
bowl not level
check for suspension bolts and insulators holding the bowl level
Posted on Jul 18, 2016
How to clean drum wont let me choose cycle ?
If it is really loud and noisy when on spin it will almost certainly be worn or rusty bearings. Workshop job to dismantle and replace the parts.
2helpful
My fisher paykel front loader is stuck on drum clean and when ever you press a button it just keeps beeping
Ignore most of these comments. The fix is simple, this machine does this to force you to run a drum clean. Simply hold the lock key button until it unlocks, then run a drum clean cycle.
I have a fisher and paykel elba washing machine and the drum is not turning during spin and it is tight and cant be moved by hand either. Water is pumping out fine but it is making a clicking sound when...
Does it pump all the water out and then just do small agitations backwards and forward and never engage into the rinse or spin cycle and never come up with a fault code, if this sounds like your problem then can most probably help as I have to encountered the same problem before and now know how to fix this fault.
2helpful
During spin cycle water on floor from outside
SEAL IS MOST LIKELY LEAKING BETWEEN AGITATOR AND DRUM, SEALS ARE CHEAP AND DEDERGENTS OVER TIME CAN WEAR THEM OUT.
Fisher Paykel Ecosmart washing machine spills water.
sometimes too much detergent, or extra cleaners like oxy clean) will cause lots of foam which will cause the water level sensor to misread, or foam over the top of the drum. if this is not the problem, you will have to tilt the machine on its side and look for loose or damaged hoses. the play in the tub will not cause leaking
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
