Question about Kenmore Washing Machines
The F5 error code indicates that the Central Control Unit (main machine control board) detects a temperature sensor resistance that is out of the normal range. The F5 error is normally caused by a failed NTC temperature sensor.
Posted on Aug 15, 2016
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Posted on Apr 15, 2007
SOURCE: error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
Posted on Dec 18, 2008
SOURCE: Error Code F-20
I have same machine and manual says, "F20" on display (water inlet problem - no water or insufficient water supply). Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following. Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re select cycle and press START. if the problem remains, call for service.
Posted on May 13, 2009
SOURCE: we are getting an error code ddo on our wahser?
The DDO error is telling you that the detergent door is open. This error occurs when the detergent door has not latched properly when the unit is started.
There is a sensor that is dependant on a magnet, that is attached to the door, to trip it and send the proper door closed signal to the control oard. If this magnet comes off, or loose the signal will not be sent to the control board, and the error code will be displayed.
Now for the bad news. The magnet is in such a position that a considerable amount of labor is required to replace it.
Unless you are mechanicly inclined and handy with a box of tools I do not recommend that you attempt this repair. It is very involved and is not a DIY repair. It is best to let a tech handle this repair. An approximate price range for this repair is $175.00 to $275.00, or more depending on where you live.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Posted on Jul 27, 2009
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
Oct 14, 2018 | Kenmore Washing Machines
Oct 12, 2018 | Maytag Washing Machines
Jan 08, 2016 | Kenmore Washing Machines
Oct 12, 2015 | Kenmore Washing Machines
Sep 07, 2015 | Kenmore Washing Machines
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Oct 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Sep 03, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Jan 17, 2021 | Kenmore Washing Machines
882 people viewed this question
