Question about AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
Posted by Anthony Gibbons on
john h
    Top Expert:
  • AEG Master
  • 23,504 Answers
What was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Posted on Jul 17, 2016
Defy 350lt upright freezer red alarm light flashing the light start flashing and the food started defrosting
Check for proper door closure or internal light function first
Next, check temp. control settings. If all checks ok, call a tech. to fix it
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Sep 21, 2017 | Freezers
Inhave just reurned from a short holiday and found My Miele f1313s freezer has the alarm light flashing. Thoughts?
Make sure you have enough amps in the outlet its plugged into. The kitchen outlet might of had more amps than the garage outlet. Also, try unplugging it for a few seconds then plug it back it which might reset it.
Sep 20, 2014 | Miele 3.7 cu. ft. / 105 liter Upright...
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
Mar 05, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Freezer alarm and signal light comes on daily
The beeping and light indicates the need for a new battery (9v)
May 22, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA Logo
390 people viewed this question
Top AEG Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an AEG Freezer Expert? Answer questions, earn points and help others
