Question about Water Sport
Question about jet ski
Will water spray out rooster tail when its hooked to test hose?
Posted by Eric Agee on
2 Related Answers
Anonymous
SOURCE: 2006 fx ho waverunner rooster tail only 6 feet
ROOSTERTAIL STOPPED WORKING
Posted on Aug 05, 2009
rsrbob
  • 101 Answers
SOURCE: rooster tail is not shooting high
If the waverunner is performing normally as far as throttle response and top speed, then the rooster tail not shooting as high as it used to indicates there is a restriction in the nozzle for the rooster tail, not a problem with the ski. Unbolt the rooster tail nozzle from the steering nozzle and inspect it for debris.
Posted on Sep 23, 2009
Testimonial: "Thanks for the info. I will give this a try."
Hi my name is Neal. I have a 2004 kaw 900 stx jet ski with the heat light flashing and when I put it in the water it will NOT run full throttle and cuts out from start. However out the water with flush...
I'm no expert on jet-skis or anything but it sounds like you may have a "water-pump" issue. In the water it bogs and cuts out..... but put a "flow" of water from a "hose" and it runs fine out the water, the flow of water surpasses the water-pump and allows flow to cool the engine. I would check water-pump before I would go too far with it. Hope this helps, Jesus loves you, John 3:16-17 (KJV)
Jul 18, 2018 | Cars & Trucks
Overheating no rooster tail nothing clogged in the impeller. Water intake is clear. Does anyone have any suggestions
Cars and trucks? if so what is make and model please, is this the correct category please. If so please clarify adding make model and engine of vehicle....no rooster tail? sorry if I have misunderstood
Sep 12, 2015 | Cars & Trucks
Why does yamaha waverunner fx cruiser ho not run in lake but will run hooked to water hose
Sounds like you have a bad stator. It may be producing enough spark to start the motor, but under a load (as in the water) it simply can not supply the amount of spark needed. Sometimes when a stator is tested on a ohms meter it may test good, but still be defective do to the load it will come in contact with when put in the water.
Jun 29, 2014 | Yamaha 12V Air Pump
Jet ski troubleshooting
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
How to maintain my jet ski?
If you plan to store a jet ski in a garage, you will need to make sure it is dry and cool and with limited exposure to the sun. In general, you need to do what you can to prevent rust and other grime that eventually may cause mechanical issues.
Washing your jet ski is also needed after every use. You can use your car wash products. I also suggest to read the user's manual, it may include tips about maintaining your jet ski.
You can protect the engine with a special spray and water repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
Jan 17, 2013 | Boating
Rooster tail is not shooting high
Jul 13, 2009 | Yamaha 12V Air Pump
My yamaha jet-ski is in learning mode. how do i turn it off?
Its going to ask for a code!!If not lift the seat find the blue plug un hook it then hook back up it will ask for code push AAA then hold it will reset it if this is digital odomtor
May 31, 2009 | Yamaha 12V Air Pump
No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Mar 16, 2009 | Interactive Toy Concepts Polaris Sportsman...
Kawaski jetski 2001 130 ultra
it is a 3cylinder 2 stroke motor. Just use 2 stoke oil. Also when done riding hook up fresh water hose and flush. also spray motor down with wd-40. Just a nice thick coat after every ride. It does WONDERS>
Jul 28, 2008 | kawasaki PVS297OS
Water Sport Logo
2,307 people viewed this question
Top Water Sport Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
