Question about Dehumidifiers
Dehumidifier blows hot air - Dehumidifiers
Posted by elio di carlo on
5 Related Answers
Anonymous
SOURCE: dehumidifier
Again, if your model is one that can be used in cooler temps so as not to ice up, the heat prevents this.
Posted on Oct 02, 2008
Anonymous
SOURCE: Overheating
Same problem, I cleaned the filter etc. seems to run ok, but gets very hot on the top and sometimes smells hot. No signs of burning etc.
Posted on Oct 15, 2008
Anonymous
  • 12 Answers
SOURCE: dehumidifier,lot of hot air blowing from the rear
I suspect that the dehumidifier coil, the section that gets cold, is clogged up with dust or dirt and this is why it is not working properly. Do not continue to run it this way or you could burn up the compressor!
Posted on Jul 21, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my dehumidifier model number FAD704DUD
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Aug 13, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Why does my dehumidifier blow
heatman101
My classic dehumidifier is not drawing water. The fan is working
if it is blowing:
room air = no cooling
hot air = unit is running
cool air = unit is trying to empty
sounds like it is NOT hot air
What causes icing in the back of the dehumidifier where the filter is
If it is blowing:
My frigidaire dehumidifier isn't not dehumidifying .is the warranty still good
Good Morning Friend,
I understand your Frigidaire dehumidifier, model# LAD704TDL, is not dehumidifying. I also see that it is blowing hot air, no water is coming out of the hose, and the humidity stays at 80%. I suggest contacting the manufacturer directly, to see if your appliance is in warranty, and they should be able to point you in the right direction. Hope this is helpful.
-Best Regards-
WP
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
1helpful
2answers
Should hot air blow out of a deumidifier
I had the same one and yes it is pretty warm air that blows out of it
4helpful
2answers
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Dehumidifier
Overheating
2answers
30 pint model # M30H3082A
A common problem - low on refrigerant. Unfortunately it's not a simple fix. Check your warranty to see if you're still covered for "Sealed system repairs"
Dehumidifiers Logo
Top Dehumidifiers Experts
Gil Shultz
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Dehumidifier Expert? Answer questions, earn points and help others
