Blenders Logo
l
linda griffith Posted on Jul 17, 2016
Villaware blender Trying to replace screws in skirt base
5 Related Answers
Anonymous
  • Posted on Nov 22, 2008
SOURCE: New part for VillaWare blender
MANUFACTURER WEB SITE IN MALAYSIA I HAVE ASKED THEM IF I CAN BUY SOME I WILL LET YOU KNOW IF THE PRICE IS NOT TO EXPENSIVE
http://www.alibaba.com/product-free/100075597/Villaware_Moderno_Pro_Infinity.html
Anonymous
SOURCE: blender
Anonymous
  • Posted on Sep 21, 2009
SOURCE: leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Anonymous
  • 5 Answers
  • Posted on Oct 20, 2009
SOURCE: Looking for a replacement gasket for the VillaWare
If any body needs any parts for the villaware 5785 series I have everything available except the plastic smoothee container. I have some gaskets. If you need it I can send it to you and you can just reimburse me for the shipping after I have sent it to you. You can contact me at [email protected]. Villaware is no longer selling the smoothee container, I doubt if they are selling other parts for it.
Anonymous
  • 5 Answers
SOURCE: spout is broken on the villaware smoothee-bar
If any body needs any parts for the villaware 5785 series I have everything available except the plastic smoothee container. I have the smoothee spout. If you need it I can send it to you and you can just reimburse me for the shipping after I have sent it to you. You can contact me at [email protected]. Villaware is no longer selling the smoothee container, I doubt if they are selling other parts for it.
I need the pitcher for the Moderno Pro model 43000 kitchen blender. Please help because the motor is great. Thanks
It appears that model is discontinued and there are no parts available from the maker. These do look similar, but it is a risk to buy when they don't specify the exact model..
https://villaware.blendersi.com/villaware-blender-parts.html
https://www.google.com/search?q=villaware+moderno+pro+43000+blender+replacement+jar
I edited your question to show 'Moderno', because 'Moderna', flooded my search with COVID-19 vaccine information!!
Apr 19, 2021 • Blenders
3helpful
Spout is broken on the villaware smoothee-bar blender. Looking for a replacement part.
6helpful
1helpful
2answers
Blender leaks
Well, that's not good. Call the manufacturer and they should be willing to dend you one. Good luck.
5helpful
4helpful
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Top VillaWare Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
john h
Are you a VillaWare Blender Expert? Answer questions, earn points and help others
