Question about Hayward Pool & Spa
Connect Hayward AquaCritter to Intex EasySet pool?
I would like to know how to connect the critter to my skimmer or if I need to bypass and hook it to my intex sand filter?
Posted by Linda Milligan on
4 Related Answers
Coastsider
Charles East
  • 331 Answers
SOURCE: Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Posted on Apr 14, 2010
Kieran Ruppert
  • 990 Answers
SOURCE: will a 240 hayward sand filter with the SPX0710X32 valve, allow
If they are to much for the pump basket you can try filter by-pass. Another thing could be a tool called a leaf master that hooks on your garden hose and sweeps any and all light stuff from pool and collects in a bag big enough to hold it all in one sitting.
Posted on May 28, 2010
Anonymous
  • 52 Answers
SOURCE: Filter assembly Intex 15X48
The lower hole is for suction and the higher hole is for return.
The Pool Tech
Posted on Jul 14, 2010
Anonymous
  • 15 Answers
SOURCE: I have an Intex Ellipse 24x12 pool. I just got an
MAKE SURE YOUR SUCTION HOSE IS GOING TO THE PUMP INLET ON THE FRONT SIDE OF THE MOTOR ON THE PUMP. YOUR DISCHARGE SIDE WILL BE ON THE BOTTOM OF THE FILTER SIDE OF THE PUMP. IT SOUNDDS AS SIMPLE AS YOU MIGHT HAVE THE HOSES REVERSED.
Posted on Aug 30, 2010
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
How do I vaccum the pool? I dont know if I turn the Veriflow to out and then where do I hook in the hose?..Its my girlfriends pool and she just expects me to know. Thanks
Oh then you DO need help. To vacuum you don't need to change the valve setting on the filter, but if there is a valve on the intake selecting main drain/skimmer you can select skimmer only, but I usually only do this after I have the hose primed. . You attach the hose to the skimmer inlet. Usually there will be a round plate attched to the hose that fits into the skimmer ( you may have to remove the basket) If you don't have that round plate on the hose, then you can insert the hose driectly into the bottom of the skimmer. Before you attach the hose, connect it to the skimmer head on the pole. Submerge the head and hose. Allow to settle to bottom. Put all the hose into the pool. Take the other end and hold over the discharge back into the pool to fill the hose with water (prime) until air bubbles stop coming from vacuum head. Then hold your hand over the hose (to keep from loosing prime) and quickly attach to skimmer. You may hear some air, and the pump may stop pumping fully mommentairly untill it is pumping full water again. Now you can select the valve to divert all the flow from the skimmer
Aug 13, 2010 | Hayward SAND FILTER, PRO SERIES
How do you hook the vacumn to the skimmer?
First connect hose to vacuum head mounted on handle. Put vaccum in water. Take other end of hose and hold over return outlet filling the hose with water until the vacuum floats up and all the air bubbles stop bubbleing. When it sinks again, hold your had over the hose and take it to the skimmer. If you have an adaptor plate for skimmer have it already on the hose. If you don't have one, then remove basket and quickly remove your hand and put hose down ito pipe in skimmer. You will get some air and once the pump recovers, and starts pupming, then begin vacuuming.
Jul 04, 2010 | Intex Pool & Spa
Hooking up five hoses to my hayward pump/filter
Your system has a suction side and a discharge side. Skimmer and bottom drain hook to the suction side. Returns (discharge) return via chlorinator or other sanitary system and heater if appropriate, to ports in the side of the pool.
May 31, 2010 | Hayward SAND FILTER, PRO SERIES
Will a 240 hayward sand filter with the SPX0710X32 valve, allow
May 27, 2010 | Hayward SAND FILTER, PRO SERIES
Apr 11, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex pool pump directions
from skimmer one hose goes into pump. outlet goes back to pool
Jun 16, 2009 | Intex 4000 GPH Filter Pump
Pool need to know how hoses hook to pool
from the skimmer to inlet pump -from outlet pump to in let filter -from out let filter back to pool return
May 27, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
135 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
