Question about Sony Televison & Video
Turning subtitles on from my hisense tv menu? i turned it on from the remote and even the TV menu. Still nothing. Only thing I have hooked up is my Sony DVD player. Plz help w/ suggestions!!
Posted by Sarah Jensen on
  • Rich Allcorn
    Rich Allcorn Apr 13, 2021
    Such a simple fix, but “spot-on”! It was THE ANSWER!
bigdawg7299
  • 2,559 Answers
You need to turn them on on the DVD player. The tv caption option is for watching over the air channels.
Posted on Jul 16, 2016
5 Related Answers
Anonymous
  • 476 Answers
SOURCE: setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Posted on Feb 24, 2008
Steve Mason
  • 311 Answers
SOURCE: Closed Captions won't work
make sure your dvd player has the capability to display closed captions, as not all of them do, also if it does have the capabilities, it may need a scart connection.
Posted on Jul 02, 2008
Anonymous
  • 17 Answers
SOURCE: Hi, how do I turn
Some DVDs can't change the Audio or Subtitles in Button of the Remote, try change in the Menu,
Try again with the Remote with another DVD Disc...
Bruno Gamba
Posted on Jul 23, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony DVP-NS55P subtitles
go to dvd set up menu and reset the settings. try again to see subtitles.
Posted on Aug 12, 2008
Anonymous
SOURCE: connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Posted on Feb 24, 2009
How to turn off subtitle without a remote on a polaroid tv
Polaroid turn off subtitles tv Questions & Answers - Fixya
www.fixya.com > Forum > Tags > turn off subtitles tv
Polaroid turn off subtitles tv related problems. ... ...subtitles on certain channels? go into menu or setup on remote there ... Not finding what you are looking for?
Nov 17, 2015 | Polaroid Televison & Video
My hisense is hooked up but says there is no signal
Using the Hisense remote, enter setup menu fpor TV. Choose SAT/Cable as signal source.
Feb 22, 2015 | Hisense LTDN50K360GUS 50" LED TV...
How do I turn the subtitles off for the yamaha HTR-5730 AV receiver? When I hook the cable up directly to the TV, there are no subtitles, but when the video output goes through the receiver, subtitles
The receiver manual may list it under "CC" (closed captions) instead of subtitles. Also, don't just check your AV receiver; try checking the setup menu on your TV, and look at the TV remote. See if there's a CC setting that may be turned on, either through the TV setup (probably under the "Display" or "Video" tab) or because you've accidentally pushed the CC (or Subtitles) button on the TV remote.
Nov 26, 2014 | Yamaha HTR-5730 Receiver
How do you shut off subtitles without remote Philips 27MS4504 TV
Try go menu on the tv control buttons on the front of the tv.Go the menu fine Captioning turn all off CC1,2,3 text 1,2 so on turn off all that should have no more subtitles.
Jan 12, 2010 | Philips 27MS4504 TV
Can't turn subtitles off
Hmm... have you tried ontop of the remote where it has "tv" vcr" sat" etc...hit tv first then try the menu?and do you have satelite by any chance? because something similar happened to me when i had my old tv put upstairs and hooked up, the remote for it did not work so i had a universal and the tv was on "video 1" input the whole time and the universal remote didn not convert it back to tv so what i had to do was hook up the reciever to the "video 1" port instead of the "tv" input in the back...i hope you get it cause i know it can be a pain in the A$$
Sep 13, 2008 | Televison & Video
Can't get rid of subtitles
Often the subtitles are a function of the TV. Check the menus on the TV and turn them off there. Sometimes merely muting and un-muting the TV is all it takes. Other times, you have to go into the settings.
Aug 18, 2008 | Sony DVP-NS57P
My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Jun 03, 2008 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
