Watches Logo
j
jorge l natal Posted on Jul 15, 2016
Invicta subaqua model no.5404 lock pin
The secure lock pin broke
How do I set the date on an Invicta Subaqua Noma watch
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
How to set date and day on INVICTA SUBAQUA NOMA III
Pull the stem out 2 clicks sets the time, pull the stem out just 1 click
turn it forward sets the day and turning the stem backwards sets the
date. I hope this helps
I need screws for invicta subaqua noma 3 band model # 6510
Good day I had purchase parts direct from Invicta and found that is easier then looking around for the parts here is the info;
Message Invicta Customer Service . Mon - Fri . 9am - 5pm EST
Email [email protected]
Call 800-327-7682 . Mon - Fri . 9am - 5pm EST
Fax 954-921-2508 or 954-862-5461
Write Invicta Watch Group
Attn: Customer Service
One Invicta Way (3069 Taft St.)
Hollywood, Florida 33021
U.S.A.
#PS
or you can also check them at their web-site http://invictawatch.com most parts are really low cost with the exeption of the mechanic parts
What powers my subaqua noma iii gmt limited edition model # foo27
It has an automatic movement powered by the movement of your arm.
3helpful
I have an Invicta Venom #6111 with Poly strap. I want to put a Stainless steel ******** instead. How do I remove the caps covering the Screws holding the ********?
The caps are just for decoration. They dont cover anything. To remove the strap, you have to release the spring loaded pins from the underside of the band. There are two on both ends. Reuse the pins with the stainless band but be careful not to have a pin go into the wrong hole because they can't be removed without breaking them!
1helpful
Need a manual describing how to set the date for an Invicta Reserve Subaqua 6208
mcdevito75 here, Best Bet, online to shopnbc.com to Invicta watches, or give Invicta a call , info at the website at ShpNBC.com
3helpful
How do you remove the links from an invicta subaqua venom stainless bracelet?
it's not much harder then normal push pins, just a little trick..push the pin out, doesn't matter which way. You will probably have to pull it out with pliers once you get it started.
once that pin is out, the band still won't come apart. There is another pin, a tube actually that the other pin went thru. it connects the center links. to remove it, you have to first remove the outer links. to do this you push them inwards, toward where your wrist would be if you were wearing it. (the links are actually two pieces-the center 'snake-skin' piece, and the outer bars. the outer bars are connected behind the center piece) the outer bars are what you push inward, they will pop out once the first pin is out.
Now you will just have the center piece connected to the adjacent center piece. That second pin (the tube) will just about fall out if you turn the band on its side. Now the bracelet will come apart.
To put back together, just line up the to center pieces, slide in the tube, then put the outer links in from behind the center piece (this actually locks the tube in place) then put in the long pin.
Ideally it will slide in halfway easily, then carefully tack it in fully. if it doesn't get in halfway jiggle the links and tap lightly. Don't use too much force until it's past 2/3 inserted or you will bend the pin.
SUBAQUA NOMA 3 SCREWS LOOSEN AND THE BRACELET OPENS ANYBODY ELSE
What 3 screws? Give me: Make, model, all the numbers on case back. Explain in detail what 's wrong. Where screws are/were located and so on.
Top Invicta Watches Experts
Ngoro
john h
Are you an Invicta Watch Expert? Answer questions, earn points and help others
