Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Will 1997lumina ignition work in a 2002 kia sedona van
Which ignitions are compatable with the kia sedona 2002 van?
Posted by Megan Murphy on
magna buff
  • 3,828 Answers
Its a car question
check the key fobs are the same for both years
and if you need a diagnostic scanner to code the keys or not
information says yes
any ignition barrel from kia sedona 1998 -2006
Posted on Jul 15, 2016
Replaced roof dvd players side bulbs lights in kia sedona 07 plate now they only work when switched not automatically when door opens?
Kia Carnival & Sedona Forum [Archive] - Kia Forum - Kia-Forums.com
www.kia-forums.com > Kia Forum > KIA Models
Jul 8, 2006 - [Archive] Discussion area for every generation Kia Carnival and Kia Sedona. ... 2006 SEDONA EX front and rear blowers dead · 2007 Kia Sedona LX 3.8L... out of the intercooler air intake · 2002 Kia Sedona Front heater will only work with a slap! ... 2003 Kia Sedona, Will Crank but not start after replacing MAF, crank and ... Kia Carnival & Sedona 2006+ [Archive] - Page 3 - Kia Forum
Apr 11, 2012
Kia Carnival & Sedona (2002 - 2005) [Archive] - Page 5 - Kia Forum
Jul 24, 2008
Kia Carens & Rondo Forum [Archive] - Page 2 - Kia Forum - Kia ...
Aug 15, 2007
More results from www.kia-forums.com
[PDF]2006 Sedona Owner's Manual - Kia Canada
www.kia.ca/.../ownersmanual/2006_sedona_Owners_Manual_E... Kia Motorsrecommended special tools, genuine Kia replacement parts and .... Room light main control switch.....3-123 ...... work properly, the power sliding door and ..... fuel only. • Check to make sure the fuel filler cap is securely closed after refu- .... roof, you have to reset your sunroof sys- ...... bulb check when you turned the ignition.
Jan 30, 2016 | Kia Cars & Trucks
My 2002 kia sedona won't idle until warms up, dies when put into gear ...any ideas??
Is the check engine light on? you could have a bad ignition fail sensor, TPS sensor, or bad o2 sensor. it could also be a bad mass air flow sensor or a vacuum leak. without a code to help pin point the problem I'd start by checking those things first. Maybe try unplugging the mass airflow sensor and start it up and see if anything changes.
Oct 03, 2014 | 2002 Kia Sedona
Does anyone have a schematic for a 2003 Kia Sedona ignition circuit? The 15amp ignition fuse keeps blowing
Go to autozone.com sign up to be a member it's free. Go to repair manual for your model and year and you can look at wiring diagrams or print them out. I have checked they do have a ignition diagram.
May 04, 2014 | 2002 Kia Sedona
MY 2002 KIA SEDONA WILL START JERKING AND LOSE POWER AND THEN WILL START WORKING RIGHT AFTER A MINUTE OR SO. WHAT COULD BE THE CAUSE
Our 2002 kia sedona mini van does the same thing when were drive and they told us it is the transmission control module tcm for short
Jan 27, 2013 | 2002 Kia Sedona
Kia sedona ex- ignition problems
Try spraying a little bit of WD40 into the key hole and see if it will turn.
Mar 14, 2017 | 2011 Kia Sedona
Kia sedona doors chime even when key is NOT in the ignition... then runs down battery
have u tried replacing the ignition switch.. sounds like that's the problem..
Apr 29, 2012 | 2002 Kia Sedona
I have an 04 kia sedona.wont start.recently had replaced timing belt complete tune up water pump serpentine belt and ignition coil.just for maintenance. It rode for about a month and then wouldn't...
recheck the timing belt to make sure it was done right,if the belt slips your engine will not start, maybe it was installed incorrectly.
Mar 29, 2012 | 2004 Kia Sedona
2002 Kia Sedona. Car wont start. We change to new ECU. Still wont start. What next to check
Did you check the ignition system? The module and the ignition usually at fault when u can't start the car! U have replace the ECU w/o any scanning by the dealers computer to check wuts wrong w/ ur car? That'll be a shot to the moon! Pls go to ur nearest dealer and have ur car scanned by their computer analyser! hope that might help u! taaah!
Nov 13, 2010 | 2002 Kia Sedona
How many ignition coils hava a kia sedona??????
6 ignition coils, one for each cylinder. 3.5 SFI DOHC.
Apr 09, 2010 | 2002 Kia Sedona
The button on my Kia Sedona gear shift is stuck
I have the same problem, its the screw in the gear shift, take it to kia they will replace it,
Jul 02, 2009 | 2003 Kia Sedona
Heating & Cooling Logo
98 people viewed this question
Top Coleman Heating & Cooling Experts
Paul Carew
Marvin
Marvin
jdthefixer
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
