Question about Coffee Makers & Espresso Machines
Capresso grind and brew model 451 coffee maker, where to find one to purchase.
Black or white, older model coffee maker.
Posted by Risa Krahmer on
  • Risa Krahmer
    Risa Krahmer Jul 15, 2016
    I bought the latest model Capresso grind and brew with the grinder in the center top, had it replaced as a stone jammed the grinder, unfortunately the beans were free from Capresso that had the stone, I've never had that happen before with coffee beans! Then I bought the model just before the newest one but sad to say I cannot get the same richness and flavor strength as I can from a cone type filter basket in the old 451 model, of which I've had two. So...bottom line, I think the coffee was better with the older models, but they're harder to find.
Trippy Tripp
    Sergeant:
  • 194 Answers
That model is no longer in production. You can keep an eye out for a used one at say ebay, one sold last year there.
Capresso does make a new grind an brew 10 cup model . Number 488.05
Posted on Jul 14, 2016
David Ellis Rhea
  • 3,462 Answers
Start by trying e-bay.
We have an older style white Bunn Pour-omatic coffee maker. Model GR. Model # D-267.325. We are looking for the nozzle that screws onto the bottom of the water tank and disperses the water into the...
you should be able to go online and locate a bunn service centre in your area, contact them and purchase a 5 hole sprayhead. It will be metal instead of plastic but will work fine.
Sep 05, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Order parts for 172165
Hello. If you are hoping to repair this and can see the crack that is causing the leak you can repair it with a marine grade epoxy. This can be found at Home Depot and most hardware stores. J.
Jul 10, 2010 | Black & Decker SpaceMaker ODC150 Coffee...
I have a Classic Coffee Concepts GB360 maker that needs switches
I have the same coffee maker which has a heater problem but the wiring is intact. The switches are wired like this:
Right Rear Warmer Switch: Top - White from other two switches
Middle: Black from other switches
Bottom: Red
Right Front Warmer Switch: Top: White shared with other two switches.
Middle: Black with connector to Black on other switches
Bottom: Blue
Lower Front Warmer Switch: Top: White from other switches and connector to white from inside.
Middle: Black and Purple together
Bottom: Black from inside and Purple from inside on a connector.
Jul 07, 2010 | Classic Coffee Concepts SSU50 Stainless...
Switch wiring
If you will get the model and date code from the bottom of the machine and contact customer service, we can further assist you.
Jan 22, 2010 | Bunn GR10 Coffee Maker
Broke glass carraffe, need to replace model 169164
I replaced my broken carafe on model: 169164 by purchasing a RIVAL 12 cup coffee maker PIL-HC08104 from WalMart for $10.24 and simply put my black handles on the new pot whaic had white handles. The pot appear to be exactly the same.
Nov 01, 2009 | GE 106591 Coffee Maker
My bunn coffee maker leaks, were can I get parts? it is the older white style
You can call Bunn Home division in Springfield, IL at (800) 352-2866. They have a kits which you can try at no charge. If that does not work, they will replace your coffee maker at discounted price provide you send the old one in. On the bottom of your coffee maker there is a modle number which they need on a white tag. .Hope this helps
May 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee Makers & Espresso Machines Logo
187 people viewed this question
Top Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
