Question about Coffee Makers & Espresso Machines
Anyone know where to find this model to purchase?
Older model Capresso, comes in black or white.
Posted by Risa Krahmer on
  • Risa Krahmer
    Risa Krahmer Jul 14, 2016
    Thank you! I've checked eBay, Amazon and Overstock, I think its becoming extinct.
David Ellis Rhea
  • 3,462 Answers
Try e-bay.
Posted on Jul 14, 2016
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Oct 19, 2012 | Jura Capresso Impressa S90 Espresso...
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
Hi, no coffee is coming out of Jura S9. The water comes out of steam exit - even in cleaning program rgds
This is a really strange error, but it makes some sense if you own a S9 One Touch model. Then there`s a problem with the squeezing valve located behind the steam/cappuccino outlet. If this is an older model, then it could be a problem with the ceramic valve, but normally this makes the water flud all over the frontpanel and inside. In both cases, i would recommend to send the machine to the nearest servicecenter.
Nov 10, 2009 | Jura Capresso Impressa S9 Coffee...
I have a 35 inch older model.heavier than heck....
this is fixable, normally it is caused by a capacitor or an ic, but it is fixable
Sep 04, 2009 | RCA 32V550T 32" TV
Need drawings for capresso ultima 121
try this sight
www.saecoparts.com/SaecoEspressoClassicoBodyparts.html - 70k -
Feb 16, 2009 | Jura Capresso Ultima 121 Espresso Machine
GWL11 Burned Up?!?!
Go and look at my issue on Eco Smart that won't drain.
Unplug washer. Bail out water as much as you can. Look for water dripping in black motor area. If you find that, read on to see if this is your issue.
You can take off black motor/white housing all in one piece. On mine, water was dripping from white plastic housing and onto motor. had small amt of water leak out, then wouldn't run at all and smelled like electrical issue. Look for white chip on upper rim of that white plastic housing where it attaches to machine bottom. Push in on clip, and give the whole white plastic thing a twist and it comes off--motor and white plastic. Unhook electric couplers.
You either have 120V or 240V (mine is older GWL10US model) unit. White plastic and black motor are one unit when ordered. Save yourself the service call that I paid. Good luck!
Oct 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Jura capresso E8
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Apr 10, 2008 | Jura Capresso C1000 Espresso & Coffee...
Wiring-
The ceiling has Black and white (dirty I expect) ,
black is hot , white is neutral
the green is ground ( the fan will ground through the mounting screws)
so connect the black to black (hot)
as you have only one choice left that is the blue/white to white.
I assume you have a strong bracket and a fan was existing previously in this spot. If not you have to install a new fan support and wiring box.
Jan 26, 2008 | Universal Remote Control Hampton Bay...
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
