Question about Toshiba Televison & Video
Hi, I have a Toshiba tv model 50HM67. I don't get a picture and tv powers on and off a couple times. There are 2 flashing orange/red lights on the front of the tv. Could the tv need a new lamp?
I have already tried unplugging the tv and plugging back in a couple times.
Posted by Tammy Sliter on
Trippy Tripp
    Sergeant:
  • 197 Answers
Yes, The t.v. needs a new lamp.
Posted on Jul 14, 2016
Testimonial: "Thank you , I will try replacing the lamp. I hope it works."
I have a toshiba 50hm67 the picture is prefect dont think the build is bad, but i have a humming coming out of the tv what could that be and how can i fix it.
If it is a high pitched or even fan like sound it may be the color wheel in that set which if I remember is not sold except with a complete light engine, do some research on that model for color wheel.
TV model 40RV753. Brand new. Setting up problem. Red/green light goes green for a very short time, during which 2 short 1 second bursts of an image with sound. light then turns to a flashing orange...
Hi Gordon,
Did you fix this problem? I have exactly the same model with exactly the same problem. I've checked the capacitors on the PSU board (as suggested in one of the responses above) and they all seem OK. If you fixed the problem, I'ld really like to know the solution. Many thanks.
Regards,
Harry.
The picture won't come on and when I push the power button it says lamp is not working
The tv "LAMP" LED light indication flashes or stay on.Ur tv the projection lamp life are over.Ur tv require a new projection lamp.
1helpful
2answers
My television is saying "I am not working" every
Then get a job like your TV is telling you. This will fix your TV, because you can then just buy a new one.
Tv wont turn on it cycles through about 5 times then it turns off blinking 2 red lights at the bottom of the monitor.
Are you sure its two red lights blinking and not the one red light blinking and you can see it through the other window to look like two red lights? If so sounds like your lamp is blown. Open the back door and unscrew the lamp (2 phillips screws) and check to see if your lamp is blown.
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
1helpful
No dislplay or sound
Could be the lamp has gone out.
1helpful
2answers
Loud pop sound now no picture or sound error message and flashing red light
Very likely the bulb has gone they have had some issues with bulbs going quite frequently on this model, bulb I believe is about £100 and an easy job on this model
I recently replaced the lamp bulb...it worked for a day and now I have sound and no picture and when you turn the tv on I get red flashing lights...and the after they are done flashing the light is blue.
You could have gotten a defective lamp. Try another lamp. Since you have a Toshiba youll be using it even if you don't need it now. Toshibas have short lamp life. If lamp does not fix then the light engine will have to be removed and sent to Toshiba to be rebuilt. They are no longer available.
2helpful
3answers
Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Televison & Video Logo
Top Toshiba Televison & Video Experts
Ekse
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
