Question about Toshiba E-Studio 356 Multifunction Copier
Toshiba e-studio 356SE error code f 121 Database abnormality user information management database
Database abnormality user information management database show display error f 121 how can solve
Posted by iftikharhmd40 on
kasun fernando
    Wolfpack:
    An expert that has 5 followers.
  • Toshiba Expert
  • 253 Answers
User management database is corrupted.
Delete the log in the following procedure:[5] + [C] +
[POWER] ? 4. Initialize database ? 1. LDAP database
(to delete user database) (Note that all user, role, group
and accounting data will be deleted.)
If the error is not recovered, reinstall the system software.
([4] + [9] + [POWER] -> 4. System Software(HD data))
Posted on Jul 19, 2016
5 Related Answers
chicagojoeco
  • 92 Answers
SOURCE: Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
Posted on Jun 28, 2009
didi2005
  • 727 Answers
SOURCE: F103 ERROR CODE IN TOSHIBA E-STUDIO 282
F103 indicates HDD transfer time-out.
U can try format the HDD (08-690).
Then u perform the bad sector check (08-694). *take long time
If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
* replacement of HDD require firmware update
Posted on Jul 02, 2009
SOURCE: Error code L
L signal is scaner lock
please chack your copier left side copy board under lock unlock mark
Thanks
Tareq
Posted on Aug 28, 2009
theinkjm7
  • 46 Answers
SOURCE: ''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Posted on Nov 04, 2009
didi2005
  • 727 Answers
SOURCE: Toshiba E-studio 600 display F130 error
The NVRAM on the SYS board stored information of MFP such as counters, serial number, settings and etc.
If u swapped SYS board, then the serial number of MFP will be different. U need to assign the correct Serial number at 08-995.
Or, use back your original NVRAM on your new SYS board.
Posted on Feb 07, 2010
Testimonial: "Thank you so much! "
How to resolve error code f120 toshiba estudio 255
Database abnormality: Database is not operating
normally.
1. Check that no jobs remain and rebuild the databases. ([5]+ [C] + [POWER] -> 4. Initialize database -> 1. LDAP DB
and 2. Log DB (Job,Msg).
2. If the error is not recovered, reinstall the system software.
Notes:
• If you rebuild the databases with a job remaining,
delete it after finishing.
• When "Rebuilding all databases" is performed, all
data including log/user/role/group/department
information and address book data are deleted. If
you back up the data in advance, they will be
recovered by restoring them after rebuilding the
database
Nov 15, 2017 | Toshiba Office Equipment & Supplies
Toshiba e studio 356se error code f121
user management database is corrupted.
Jul 14, 2016 | Toshiba Office Equipment & Supplies
Recover data from corrupt .mdf and .ldf files.
You can find more information here:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/569-i-have-a-problem-how-do-i-fix-a-corrupted-database-file
Open your SQL Server Management Studio console. This application shortcut is available in the SQL Server directory in the Windows Start button.
· Enter the system administrator user name and password. SQL Server's administrator user name is "sa." This account is required for privileges to restore the database. If your restoring on a host provider server, use the administrator user name and password they supplied for your account.
·Right-click your database name and select "Attach." In the new window that opens, click the "Add" button to open a dialog box.
·Select your MDF file and press the "Ok" button. It may take several minutes to restore the database if it is a large file. Once the process is finished, browse your tables to verify the data. The database is now restored.
If nothing helped try to use:SQL Server Fix Toolbox
http://www.fixsqldatabase.com/
Nov 28, 2014 | Microsoft SQL Server 2000 Standard Edition...
How can I repair a corrupted MDF files and SQL server?
Similar question has been answered here: http://www.fixya.com/support/t24364927-sql_repair_recovery_process_very
Before asking any question in the forum, first you need to search your problem.
May 12, 2014 | Microsoft Database Software A5K-02817 SQL...
When I trying to open the archive files, error "RRV Bucket is corrupted" is displayed. I am unable to solve this problem. can you please provide a solution. I understand data can be retrieved ,...
If this error occurs in a case where Shared Mail is being used, then first refer to the documents titled "'RRV Buffer Overflow' Error Message While Attempting to View a Mail Document" (#1093390) and "Using the OBJECT COLLECT Server Task to Manage Shared Mail Databases" (#1088860).
If the database is not in R5 format (ODS 41), then from a Domino 4.x server run Compact -M on the database. On a Domino 5.x server simply run Compact on the database. If updating the ODS to 41 does not resolve the issue, refer to the document titled "Database Has Grown too Large; Use File New Replica...' Error Occurs When Opening Local Database" (#1102305).
If none of the above resolves the issue, then where possible, a new replica should be made. If a replica is not available, restore the database from a backup, if one exists.
Supporting Information:
Corruption can be caused by many things, but a possible cause for the error in this case was that a third-party application had altered the physical location of the database on the hard disk, resulting in the Record Relocation Vector table being incorrect and the information not being located. This has been reported to happen with customers using a disk defragment utility while Compact is running.
May 28, 2011 | Computers & Internet
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
May 31, 2010 | Microsoft Visual FoxPro Professional...
Display F120 error in my Toshiba etudio 230
F120 indicates database abnormality.
What u can do:
1. Rebuild the database ( 08-684 )
2. If the error is not recovered, initialize the HDD. (Enter “2” at 08-690.)
PS: Press "0+8" & ON the machine in order to enter setting mode.
Jul 28, 2009 | Toshiba e-Studio 232 Black and White...
Database talks to code but code won't talk to database
Make sure you are connecting to the database,then just before you call your sql to insert use an echo statement to display the sql and check it for syntax:-
$sql = 'insert into table1 values('.$no.','.$no.',"block","'.$value3.'", "'.$value4.'")';
echo "SQL ==>" STARTOFSQL<br>".$sql." ENDOFSQL<br>";
Jan 18, 2009 | The PHP Group PHP
DATABASE ERROR
Download the updated version of the Philips Device Manager from www.usasupport.philips.com
Once you have downloaded the latest version, run the "Update" function in the Device Manager, and it will upgrade your player's firmware. It will solve most DB corruption issues.
-Tha Mp3 Doctor
Jan 10, 2009 | Philips GOGEAR SA6045 MP3 Player
SQL Server 2000
An easy way to transfer objects (tables, user defined functions, stored procedures, etc.) is to use Enterprise Manager's "Generate SQL" feature. Use this process at your own risk. Doing it wrong could mess up your existing database.
1. In Enterprise Manager, right-click on the old database and choose "All Tasks" then "Generate SQL Script".
2. In the dialog that comes up, click "Show All" then select the checkboxes for "all stored procedures" and "all user defined functions". (You might also want to check some other boxes, depending on your exact situation.)
3. Click the "generate" button and save the script that it creates.
4. Run the script in the NEW database.
If you run the script in your OLD database, it may destroy your objects, and that would be very bad. Make sure you run the script in your NEW database. (While we're on this subject, it's a good time to mention that you should back up your database before you start this process, and you should make changes to a test system before migrating it to production.)
That should move your stored procedures and user defined functions over.
You can use a similar process to move tables, views, users, and other objects over as well.
Jan 17, 2008 | Computers & Internet
Toshiba E-Studio 356 Multifunction Copier Logo
398 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
