Question about PfaFF Sewing Machines
How to thread bobbin 451 Pfaff
Bobbin loader is on the front of machine.
Posted by Eve Kammers on
R.A. Ellis
  • PfaFF Master
  • 12,731 Answers
Having difficulty even locating a photo of the 451. Assuming this is an older model, perhaps this manual will help. It says its also for the 551, so perhaps the model is close enough that it will help you with your machine:
Pfaff 551 Manual pages 1 viewing
If you are unable to figure out the bobbin winder, you may be able to use a standalone bobbin winder (one brand is called Sidewinder) from the fabric store. They run ~$25-30. Just be sure to bring a bobbin with you to check the fit.
vintage sewing machine bobbin winding Google Search
How to Wind Bobbin and Thread Bobbin Case for Vintage Singer Featherweight...
Posted on Jul 14, 2016
The top thread will not pickup bobbin therad it is a pfaff 5.0 machine
The bobin may not be in correctly. When looking at the bobin, with the thread threaded through the bobbin case, make sure that it spins counter clockwise. Also the problem could be caused by the machine not threaded correctly. But it is more likely the bobbin case and bobbin
May 04, 2017 | PfaFF Sewing Machines
This is on a 5.0 pfaff sewing it will build a bird nest below the plate
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point (may need to tweak this for your particular machine).
Remove the bobbin thread from the machine. Reinstall the bobbin in the bobbin case confirming the bobbin is turning the correct direction and the bobbin case is correctly threaded.
Pull the bobbin thread up to the top of the fabric and gently hold both thread tails in your left hand when slowly taking the first couple of stitches.
Apr 30, 2017 | PfaFF Sewing Machines
Pfaff quilting machine bobbin stuck
Is there is a wad of thread that is holding the bobbin captive? If so, you'll need to use small scissors and tweezers to snip away and pull out the threads. Patience!
If the bobbin is actually stuck in the bobbin case, it could be because it is the incorrect bobbin for the machine or the bobbin was over-filled with thread. You may just need to use force to remove the bobbin. It may damage the bobbin and, possibly, the bobbin case. They are both replaceable. Or you can pick up an additional bobbin case and bobbin and try the new ones in your machine.
Mar 10, 2017 | PfaFF Sewing Machines
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
My bobbin winds unevenly, there is always more thread at the bottom of it than there is at the top. Neither switching to the original pfaff bobbin nor either spool position works.
I always use my finger to guide the thread as the bobbin is winding,the bobbin shouldn't be moving around in the metalcase probably needs tightened.
Aug 29, 2015 | PfaFF Sewing Machines
Pfaff 1221: was sewing fine; now top thread doesn't catch bobbin thread
try rethreading the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and if that doesn't help, the problem could be a timing issue and would require a sewing machine shop
Apr 15, 2015 | PfaFF Sewing Machines
Pfaff 4.0 quilt expression pulling bobbin thread up to top of fabric help.
try a new needle
rethread the machine top & bobbin
try adjusting the top tension just a touch to see if that helps
clean under the needle plate & in the bobbin area for loose threads
or lint
make sure the bobbin is wound correctly & inserted into the bobbin
case correctly
Jun 04, 2012 | Pfaff Creative 4.0 Sewing Machnie
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
Loading a sewing macheine
There are two threads you're asking about, or could possibly be asking about. The first is the top thread. There is a diagram across the top of the machine with numbers(1, 2, 3, etc) detailing where to put the thread and how.
Your bottom thread, otherwise known as your Bobbin, will have the same diagrams, depending on whether it is a top loader, or a front loader. If it is a top loader, simply remove the bobbin door, and drop in the bobbin, making sure the thread is facing the direction the diagram tells you it should be facing. For a front loader, the diagram will also ensure you know what you're doing, often with a bobbin case involved.
Apr 23, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
53 people viewed this question
Top PfaFF Sewing Machines Experts
Richard Schabler
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
