Echo Backpack Blower PB-500T Logo
Joe Moffitt Posted on Jul 13, 2016
Where can I order the adjustment tool for the needle screws on an echo pb-500t back pack blower?
5 Related Answers
Anonymous
  • Posted on Aug 12, 2009
SOURCE: Echo PB-413H bogs down
Echo tools have a screen in the muffler to arrest sparks. Take off the muffler and remove this screen
Jeff Hagemann
  • 430 Answers
  • Posted on Nov 30, 2009
SOURCE: ho spark on a pb 403t backpack blower
Be sure you have no spark ( 90% of the units that come into my shop for repair with the complaint of no spark- have a fuel issue). Be sure the spark plug is good.
If no spark then remove the ground wire from the module and check for spark again. You must use the recoil starter- spinning by hand is not sufficient. If still no spark then replace module. If there is spark with the ground wire disconnected then there is a problem with the kill switch or a bad wire.
roadtech7
Matt Olenzek
  • 297 Answers
  • Posted on Dec 11, 2010
SOURCE: can't find serial # on Echo PB-500T Blower
The number is on the side of the recoil starter, its on a white or silver tag mounted on the underside.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
bryan st
  • 123 Answers
  • Posted on Feb 26, 2011
SOURCE: what is gas:oil mixture for Echo PB-500t blower?
50:1 ratio, 2.6oz of 2 cycle oil to 1 gallon gas
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Jul 03, 2011
SOURCE: ECHO PB-250 blower new used one time carb.needs
Your machine has a rotary-valve diaphragm type carburetor. These carburetors typically only have an adjustment for the IDLE speed with an available option to control the main jet with an adjustable mixture needle.
http://www.echo-usa.com/Products/Blowers/PB-250
Here is the info on the Zama rotary-valve diaphragm carburetor.
http://www.zamacarb.com/prodlist.html#RB
Some have a small adjustment needle in the center pivot of the rotory part, under a brass plug...but most have nothing. Many end users and techs are complaining about the non-adjustable carbs. They are made this way to meet the more stringent EPA emissions codes that are getting tougher each year.
I have echo pb 500t blower where can i find a tool to remove the 4 bo!ts holding the head on ?
There is no special tool. The bolts are hex heads are require a hex tool to remove them. These can be found at any auto parts or home improvement store. Also, just an FYI, the head and cylinder are on piece on this model.
Oct 28, 2020 • Echo Garden
Purge bulb not working on echo pb-500t,gas leaf blower
get a new primer bulb and diaghram and rebuild your carb or buy a new carb,same price,gas and ethanol and oil kill carbs, echo A021000781
Echo PB 230LN 05001001 05020818 Handheld Parts
May 26, 2015 • Echo Garden
Why does my blower floor out to kiwk
adjust need and seat or make sure needld a seat or seated right soundes like not should be no need to adjust needel sounds like put in wrong flip it over metal side go on needle
It want crank at all i just rebuilt the carb and still want crank and now it also has gas coming out the muffler
you either have a bad carburetor or you didn't put it together right when you rebuilt it. double check the diaphragm is on top of the gasket on the metering side. if the needle is stuck open the fuel will continue to flow causing it to come out the muffler
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Oct 24, 2012 • Garden
3helpful
2answers
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
2helpful
2answers
ECHO PB-250 blower new used one time carb.needs adj.can this carb.be adjusted
13helpful
1helpful
Can't find serial # on Echo PB-500T Blower
Dec 10, 2010 • Echo Garden
4helpful
2answers
Top Echo Garden Experts
john h
Ngoro
vince
Are you an Echo Garden Expert? Answer questions, earn points and help others
