Question about Baby Gear
How do I find the instructions to set up the babi Italia pinehurst as a full bed?
We have the rails, but no instructions.
Posted by Kelly Urk on
andrew petersimes
    Sergeant:
  • 248 Answers
How do I obtain replacement hardware for a Pinehurst classic crib made by Baby Italia?
Here are some common crib manuals for the Baby Italia product line. You might check here. You can download in PDF.
http://www.lajobi.com/resources/assembly-instructions
Sep 11, 2014 | Baby Gear
I need all of the hardware for my pinehurst lifestyle crib how do I go about trying to get it?
www.productsamerica.com or call the maufacturer. I've always had good luck callin the manufacturer
Jul 22, 2014 | Babi Italia Pinehurst Lifestyle Crib Bed...
I have a Babi Italia dated 07 aug2003 is there any recalls on it I just got it and it doesn't seem safe the drop side just popped out when my 8 yr old tried to give my 9 mth old his pacify
I'd get rid of the thing. there are new standards for baby cribs for 2011. Also, if the thing is over 8yrs. old, its probably too old and the mattress is full of dirt and whatever. Consumer Reports is a great resource to find what your baby needs. Sales can't tell you if one is recommended because doing it is illegal and they will get sued by the Consumers Union, the nonprofit that puts out the magazine. If your 8yr. old can accidentally open it just doing that the baby may do it just by turning over. Throw it in the trash or send it to recycling. Rock-a-bye healthy baby.
Feb 03, 2013 | Babi Italia Serta Perfect Dream Crib and...
Need Instructions on how to put together a Babi Italia Pinehurst Drop Side Crib. May need new hardware to attach drop side to the bed.
You have it made on this one! Follow this link for RECALL info and a FREE IN HOME
TECHNICIAN VISIT to put it togethe for you! How sweet!
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09239.html
Feb 21, 2011 | Baby Gear
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 | Baby Gear
I have a europa baby chatham lifestyle crib. color is tea stain. date of production is May 18, 2006. I am looking for a conversion kit to convert from the crib to the toddler bed. where can I locate a...
I know its been a while but if you're still looking for the toddler rail or even the full size bed rails call Lajobi (the manufacturer) at 888-266-2848 or email them at [email protected]. I bought this same crib in 2006 at Baby Depot and I ordered the toddler bed rail through them in 2009 for around $60. Now I'm ready for the full size bed rails but the crib has been discontinued. The manufactuer has a compatible bed rail in the same tea stain for $149 plus shipping.
Oct 12, 2010 | Toys
Instructions To Convert Jardine Madison Life Time Crib
To convert your crib to a Full Size bed you will need to purchase a set of full size bed rails (hook style for headboard and foot board). You can find this at any discount mattress store, or furniture outlet, it can range in price from $39.99 - $99.99. To install the rails you will see slots with bars on the headboard/footboard, this is where the hooks on the rails slide into. There are no bolts used to secure the rails to the headboard/footboard.
Jardine enterprises does not make a wood rail kit as was shown in some of the earlier ads for the Madison line of convertible cribs, and do not waste your time ordering the rail kit from Babies-R-Us as it is simply a metal rail kit (which you may be able to get cheaper at a local furniture/mattress store).
Use the lower daybed rail between the two front posts for the foot board. Another option for the full-size conversion is to purchase the metal rails (hook style) for a headboard only and not even bother with a foot board.
If you are still unsure of what you need to do for the full-size conversion please feel free to email me at [email protected]
Feb 21, 2009 | Baby Gear
Conversion instructions from crib to full size bed
check this website. www.babysdream.com/Service/AssembIns/pdf/Convertible%20Generation%20Next%20Crib%20Instruction I needed the instruction to convert my daughters bed and was looking for some help and notice your question.
Good Luck
Dec 27, 2008 | Babys Dream Generation Next Crib
Baby Gear Logo
Top Baby Gear Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Baby Gear Expert? Answer questions, earn points and help others
