For radio codes follow this link: Car radio codes in Uxbridge London Gumtree
Can find your factory car stereo radio code We can help I have also run into this same problem Jamie. Good luck and leave feedback
SOURCE: I have a philips ccr600 car radio and need the
Unfortunately this is insufficient information to obtain a code.
There should be a 14 character Serial Number beginning with
RG++++++++++++ or GM or RN or PH or similar somewhere on the radio.
If you are having problems reading it then try asking here
www.ukkbookshelf.co.uk
as they can provide free advice + code for these awkward problems.
Mention this forum
Otherwise it will have to be taken into a Decoding Service who will plug in a laptop to read/recode the memory chip (EEPROM)
SOURCE: phillips ccr600 radio code is missing
First make sure that the code has not been noted somewhere
within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be
removed from the dashboard (and if you are lucky, someone may have written the
code on the casing ) .
If not then POST A NEW QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on
ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the
Serial Number
Otherwise try your Main Dealer ...........or take it into a
Decode Service who will plug in a laptop to read/recode the memory chip
(EEPROM). This takes a few minutes and shouldn`t be too expensive
Testimonial: "thanks for the info , i will try what you said regards steve"
