Question about Simplex Locks & Locksmithing
SOURCE: We have a Simplex LL101126D41
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from
this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
Good Luck!
Posted on Mar 06, 2011
Testimonial: "The information was exactly what we needed."
SOURCE: We are trying to recode
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=14
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
SOURCE: Need to change the combination
Hi Don,
Got these instructions from: >>>> http://www.indra.com/archives/alt-locksmithing/hobbit.html >>>>
"Once you know the current combination, you might want to change it.
Instructions for doing this undoubtedly come with the lock; but it's real
easy. There is a screw in the top with a hex hole; remove this from the lock
body. Dial the proper combination, but don't move the handle. Press straight
down through the hole with a small screwdriver, until you feel something go
"thunk" downward. The lock is now in change mode. Reset the tumblers
[leftward twist], enter your new combination, twist the handle as though
opening the lock, and your change is now in effect. Re-insert the screw.
This does the following: The thing you hit with the screwdriver pushes the
tumblers down onto the locking bar [which is why the proper combination must
be entered], and disengages them from their idler gears. Button presses turn
the *idler* *gears* around, and then the opening action shoves the tumblers
back up to mesh with these gears in their new positions. A subsequent reset
mixes the tumblers up again to follow the new combination. This description
is admittedly somewhat inadequate; the right thing to do is take one of the
locks apart and see for one's self what exactly happens inside."
Hope this helps. If it does. I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 16, 2011
SOURCE: how do i change the
I'm not sure of your exact model, but I think you will find the information that you need listed on this grid chart:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
You can cut & paste the link or type it into you browser's search bar.
Hover your mouse over the right-most column (Tips) for your model and you will pop up links for Changing the Code or Resetting the Code.
These are PDF files, requiring that you have Adobe Reader or equivalent installed on your computer in order to view them. If you're not able to view them install Adobe Reader from this link:
http://get.adobe.com/reader/
Posted on Jul 14, 2011
Apr 01, 2012 | Locks & Locksmithing
Aug 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Apr 01, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Feb 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Jan 26, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Jan 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Dec 18, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Nov 22, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Mar 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
1,070 people viewed this question
