It it is a plumbed in unit running off utility water supply, there is a small ceramic water filter assembly that can be fitted into the water inlet side of the unit
because it is extremely fine it removes the contaminates that make the taste if that doesn't work you can fit in tandem a charcoal filter after that ceramic to guarantee perfectly clean tasteless water
add to the fact that every 12 months ( depending on volume usage) the ceramic filter can be removed and the contaminates scraped off the surface using a knife which regenerates the filter
if it is bottle feed then clean out the holding tank using bleach, wash thoroughly and allow water to run from both taps for a few minutes to remove all residue bleach , the fit new water bottle
spare bottles are subject to algae growth ( taste ) if stored in a well lit area so store spare bottles in a dark room ( closet , under bench etc )
