Question about Hotpoint Washing Machines
Where is the reset button on a hotpoint aquarius condenser drier tcm850 8kg
Posted by Victoria Perry on
5 Related Answers
Anonymous
  • 90 Answers
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
Posted on Feb 10, 2008
Anonymous
  • 101 Answers
SOURCE: hotpoint aquarius condenser drier.
Check the motor that could be short.
Posted on Apr 21, 2008
Anonymous
SOURCE: showing test on front of hotpoint washer/dryer aquarius
hotpoint aquaris washer/dryer, press and hold cancle and start untill all lights come on,then press and hold on/off and cancle /start untill doff appears then the test mode has been reset
Posted on Nov 27, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: I have a hotpoint aquarius
Most washers made today, are cold fill only, best way to check is look at rear of washer, and if there is only one hose, then it is cold fill only, if 2 hoses, then hot and cold fill..
So if your boiler is not working, then it should be o/k to use if cold fill only.
Plz rate my solution.
Thanks.
Posted on Jan 25, 2009
Anonymous
  • 14 Answers
SOURCE: aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Posted on Sep 07, 2009
My hotpoint aquarius tumble drier is making a very lound griding sound as it turns. What can it be and can it be repaired by myself? the drier is over 8years old is it time for a new one?
This is the plastic "wheel" on the motor that drags the drive belt to spin the dryer. you will need to push back into place with something thin. under the right hand side of the dryer there will be a grill under the motor. look for a black plastic "wheel" and move it away from the casing with something that can fit through the grill.
May 16, 2010 | Dryers
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1100 - door won't open
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Drier not working
take top off. you will see drier manifold going across top of machine with stats mounted on it. one or more of these stats is resetteble ie has a little button in the middle. press to reset. some hotpoint have a thermal fuse mounted on the manifold so if present, check this for continuity as well. with top still off, put on dry and check fan working as well.
if you get it going and fault reoccurs, then there is a blockage in the drier duct
Jun 22, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryer cutting main power off after acouple of seconds
your heating element is the most likely cause of this. will need replacing
Nov 18, 2007 | Hotpoint TDC32 Electric Dryer
CTD40 Aquarius Condenser Dryer
This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Oct 20, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
697 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
