Question about Sony DDS SDT-5000 DAT Tape Drive
Ive just bought an old sony dat drive SDT-5000 and want to use the external housing frome one I already have. Does anyone know how to set the jumpers? I can supply an image of this if it helps
Posted by ges1 on
  • 1 more comment
  • ges1 Oct 14, 2016
    Image of the jumpers attached.Drive appears to run fine, accepts a tape but is not recognised by my mac?
  • S Hunter Simpson
    S Hunter Simpson Oct 14, 2016
    does the enclosure have a scsi cable connector (I want to assume that's connected when you are trying to see it, but best to be clear and sure)? jumpers won't provide the data transfer, just settings (see attached jumper setting pic)
  • S Hunter Simpson
    note the jumper setting for a slightly different model, but you get the idea hopefully (one end is SCSI ID and maybe the other end has your cables attached; play around with combos; again, assuming the wide flat ribbon cable is attached, which I don't see in your pics)
S Hunter Simpson
  • 25 Answers
Supply an image (and would be great if you could supply image from old broken one and new one)
I'm a bit confused though: if you have an internal working sdt-5000 that you want to put into an external broken sdt-5000, it should be as simple as getting the enclosure open, then swapping the internal drives; i.e. external enclosures usually still use the same spec internal drive so it would just be an ide or scsi connector cable.
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
Posted on Oct 13, 2016
1 Related Answer
Gale Todd
  • 1116 Answers
SOURCE: We have SONY Model SDT-5000
What is the drive doing or not doing?
Do you have power?
Does it accept a tape?
If yes, does it rewind the tape?
Is this an internal or is it enclosed in a chassis?
Posted on Aug 15, 2011
Tar /dev/st0 can't write: error
Sounds like your tape drive or possibly the tape you are using is faulty.
check the following:
#1 - use a different tape
#2 - check that the read-only is not enabled on the tape(s)
#3 - run diagnostics on the drive (if it's come with software for diagnostics).
#4 - return it to the supplier to test and replace if under warranty.
Apr 04, 2010 | Sony DDS SDT-S9000 DAT Tape Drive
I have a sony vaio vgn-a290 laptop and im trying to reset the bios password. Ive found the dipswitch on the mother board but dont know witch one resets the bios password. could anyone help me
Pull cmos cell from motherbord for 10 minutes so all settings are goes to defaults.
Also you can reset its settings with jumper settings.
You can see 1 jumper onmmotherbord near cmos cell.
Read carefully on bord you read there RESET or CLEAR bios.
it has 3 pins.set jumper in 2-3 position then power up .
Then again set to its original position 1-2.
Then all settings defaults.
Let me know if you need more assistanse.
Thanks.
Sep 01, 2009 | Computers & Internet
I bought new computer and i want to transfer my quickbooks 2005 to new , with my files. how do i do that?
You can either put in the old hard drive into your computer and set it as a slave with the jumpers on the back.
Go to a specialists and they'll transfer it for you for a fee :(
Buy an external housing case for your old HD and then xfer it that way.
Oct 20, 2008 | Computers & Internet
Unlocked tapes recognized as locked
this is probably due to a stuck microswitch in the tape drive unit as the locked tag presses a microswitch when loaded it is possibly these microswitches that are failing, as one of the switches detects if a tape is loaded and the other detects is a tape is locked, so problems with these switches would mean that it cannot detect if the tape is loaded properly.
Sep 30, 2008 | Sony DDS SDT-D11000/ME DAT Tape Drive
PATA hd slave to SATA hd
Please one hard drive main disk and second one is slave so like this please remove the jumper for second one so first one is having the vista os (SATA) your computer will run normaly then attach the seond hard drive as slave (remove juper drive) you can see the dat (PATA)
Jul 18, 2008 | Computers & Internet
Need help on how to attach jumpers on Maxtor Hard Drive Model # 4D040H2
It is in my experience with hard drives used in external USB enclosures - the jumpers are not nessessery.
Jul 04, 2008 | Maxtor Hard Drive
Sony DDS SDT-5000 DAT Tape Drive Logo
595 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
