Question about Bulova Watches
I have got a Bulova Accutron from the fifties or sixties and would like to know what parts on are real gold and plated gold it says is 10 carat
Posted by Ken Crow on
  • Bulova Master
  • 18,520 Answers
Http://www.mybulova.com/
Posted on Jul 09, 2016
5 Related Answers
Jackalltrade
SOURCE: BULOVA WATCHES
Most watches have the gold content engraved inside tha back cover. Open carefully!
Posted on Apr 21, 2009
Anonymous
SOURCE: i have a bulova accutron with a 14KT gold case.
Since the serial number (E66289) begins with a letter, the watch was made in the United States. (Serials that begin with a number indicate the watch was made in Switzerland.) Look at the back again and see if there's a two-character code, such as M2. Compare the code against the list on the following link to find the year of manufacture: http://www.thewatchguy.com/pages/BulovaSerial.html
If it's an Accutron, visit this site to see if it's a 214. He's got a wealth of info on 214s! Good luck!
Posted on Jan 26, 2010
David Tolond
  • 2501 Answers
SOURCE: Bulova 14k Solid Gold woman's watch. Swiss 17
This sort of information is only likely to be available from an authorised dealer.
If you go to the Boluva web site, you will be able to use their dealer locator to find the one nearest you.
Posted on Mar 17, 2010
David Tolond
  • 2501 Answers
SOURCE: I have a Bulova Accotron (M7) Is it automatic
If you go to http://www.bulova.com/service/servicecenter.aspx, you will be able to locate the nearest service center, who will be able to advise you. (incidentally, after such a long time idle, it may need servicing).
Posted on Apr 08, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: How do I remove the back of my Bulova Accutron
mcdevito75 here, You will need a screwdriver to use in the slot for the battery cover or a coin, once you have the tool for the slot turn the cover just a bit and lift it off to get to the battery.
Posted on Jul 31, 2010
I'm buying a necklace and pendant that says platinum plated and 14 K gold is it real and what does platinum plated mean
14 k and platinum plated are just words to make junk jewellery look more expensive
real gold is stated in C not k as the word is spelt carat
platinum is a precious metal but when used with the letter K it indicates that what you are looking at buying will have very little value in real terms
Jun 02, 2017 | I'm Watches
Any idea what a Bulova watch, 14K white gold, number on back case 962158. Any idea what it is worth?
I'd need more info. First, is it a "real" Accutron, made from '60 to '77, or is it one of the things Bulova kept calling Accutrons after they stopped making the tuning fork movement watches? The quartz so-called Accutrons are just a nice old watch, not worth anything special. The self-wind "Accutrons", which Bulova is making now, are just a nice, mid-range aurtomatic watch. On the back of Bulova watches is a date code, usually right under the serial number (SNs themselves really mean nothing where Accutrons are concerned). The code is a letter and a number. If it begins with the letter M, or if it begins with the letter N and is followed with a 0, 1. 2. 3. 4. 5. or 6, it is a "real" Accutron, and is collectible. Some with N7 (1977) are also, but it depends on the actual watch. Bulova did make some quartz so-called Accutrons in '77. If it's a '60 thru '76, and SOME '77s, it has value beyond the scrap gold price. SOME Accutrons are even worth thousands of dollars. White gold Accutrons, compared o yellow gold or stainless, are rarer. Next, WHICH Accutron is it? is it a 214, a 218, a 219, a 220, a 224, or a 230? If it's a man's watch, it is very unlikely to be a 220 or 230 series, If it does not have a winding stem on the side, it is a 214. 214s are the most valuable. If it has a setting stem at 3 o'clock or 4 o'clock, it is either a 218 or 219 (I'd have to open the back and look at the movement to say which ine). If it says "Accuquartz" on the face, it's a 224 (NOT a quartz - the 224 Accuquartz is a hybrid of tuning fork and quartz crystal). Once we know the movement series, we need the case type. Certain cases are much more valuable than others. Then there are the Spaceview, the Astronaut, and the Deep Sea, 3 specific models they made, which are more valuable than most (but not all) of the other cases. The best I can say right now is that, being white gold, there's a good chance it's one of the more desireable specific models. If it's a 214, ESPECIALLY if it's a 1960 (M0), it's worth quite a bit more than just the gold content. To be more specific, I'd have to see a picture of the watch, which I don't think can be posted here. Try looking up "Accutron" on Ebay and see if you can find one that, if yours has a stem, has it in the same place as yours, with the exact same case - same shape, and exact same lugs (the things on either end where the band or strap is attached). Read the description. The description will probably say the movement (214, 218, etc - in fact, the movement may even be in the listing title) and if it is niot just a plain round case, probbly will say the case type (Alpha, Asymmetric, Butterfly, etc.). If it's an Astronaut, a Spaceview, or a Deep Sea, it will certainly say that. Also, look at the Accutron section of the Bulova entry in Wikipedia. (Yeah, I wrote it, but it has info that just might help you pin down exactly what you have) When you find out more about which Accutron it is, post another question under Axcutron watches here. I'll check every couple of days for the next week or so, and if I see your post, I'll narrow down the value some more.
Sep 17, 2013 | Accutron Swiss Watch by Bulova 26B44
I have antique womans gold nugget bulova watch with 014ko and 890643 on the back of the watch should I throw this away
Don't throw it away! Bulova have a good reputation. It ma not be worth much, but you have the serial number and the 14k probably means it's 14 carat gold. 14 carat old is the highest quality used for watches (18 carat is too soft for everyday wear) I used to work for Shackman and we made watch cases and bracelets for the major brands such as Omega.
Trysearching for Bulova watches on eBay then looking at 'completed listings' under 'advanced' after you search for some idea of value.
Regards, Andy
Dec 21, 2012 | Bulova Watches
BULOVA ACCUTRONE E66831 M8 14KT WIND STEM AT 4 OCLOCK NEED TO KNOW IF IT IS WORTH MORE THAN THE GOLD CASE THANKS
The M8 indicates this watch was produced in 1968 and probably sold for 250-350,this is a tuning fork watch and they are highly collectible and worth up to twice the value of the gold or more depending on the model and condition
Nov 20, 2011 | Accutron Swiss Watch by Bulova 26B44
Bulova quartz swiss 97c12. It got passed down to me and i am trying to see if its real. i can not find it anywhere. please help.
Bulova watch is one of the classic watches in the market. You must be given a product ID and code with you so you can check and confirm from the website of Bulova by entering your product code and Id on their website so that you may know that it is real product or fake. Just visit the website at
www.bulova.com
Sep 19, 2010 | Watches
What is the worth of a bulova accutron 14kt gold mother of pearl face serial #59252 worth
mcdevito75 here, Bulova Accutron, nice watch, of course there are many, many factors that go into the value of any watch, depending on Maker, Model, Condition of the watch also. I would figure your Bulova Accutron is in the area of $125.00------- $200.00 range. Your best bet is to find a jeweler in your area or an appraiser, even online for the latest value of your watch.
Aug 15, 2010 | Bulova Wrist Accutron Lucerne White M. Of...
I have a bulova 18K gold men's wrist watch, which says 3063-5020 AO in a square on the back. Swiss A6 18K. And it is a battery watch, and is still running any idea? of year or price it is very heavy on the...
mcdevito75 here, The movement number tells all, but I would figure the yaer somewhere in the 80"s and value at $250----$350.-- Accutron very collectable watch. Look for a small watch repair shop in your area for more accurate info. Hope this hepls.
Aug 02, 2010 | Accutron Swiss Watch by Bulova 26B44
Watches Logo
26 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Lisa Christine
Are you a Bulova Watch Expert? Answer questions, earn points and help others
