Question about Zebco 202 Spincast
How do I attach the Zebco 202 reel to the rod?
Posted by Corlyn Haring on
aroostookb
  • 98 Answers
Zebco 202 has a foot projecting from the frame.....this is mated to the reel seat area on your rod and the knurled rings on the rod are tightened down over it to secure it for fishing.
How do I attach the Zebco 202 reel to the rod? - attach-zebco-202-reel-rod-rs5jrq03go4hubylocmbbsxl-1-0.jpg
Posted on Sep 04, 2016
How do I remove the front cover from the zebco 33 reel???
Turn the screw a 1/4 turn, then twist the front line cover left to remove it. It may be stuck but this is how you do it. It will move about an 1/8", then pull it straight off.
Oct 31, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
Zebco reel schematics
Check with Mike Willey of The Reel People Home
He has a database of schematics.
Aug 07, 2014 | Quantum Cabo Pts Spinning Reel, Model...
Zebco manuals
That would depend on the rod, but usually either the front part of the hand grip can be unscrewed, or there is a screw under the rod that will loosen it.
Jul 26, 2014 | Zebco Spincast 33 Rod and Reel Combo
Zebco 202 Spincast Logo
721 people viewed this question
Top Zebco Fishing Experts
Thomas Perkins
Thomas Perkins
ray gallant
Arthur
Are you a Zebco Fishing Expert? Answer questions, earn points and help others
