Question about Makita Drills
Makita 18 volt hammer drill is slipping and is not closing Plastic cover has no traction . Teeth are stuck in open... does anyone suggest a fix please ?
Posted by Aaron Brady on
  • Brett Duxbury
    Brett Duxbury Jul 09, 2016
    Hi Aaron Brady, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    does the back of the chuck have a movable part that locks in the chuck try pulling apart this piece
2 Related Answers
Joe Hogan
  • 10865 Answers
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Posted on Apr 30, 2009
wiringlunati
Charles Reifinger
  • 576 Answers
SOURCE: I have an 18 volt hammer drill combo drill. I
Do the same in reverse, if possible. Also, you could use two channel locks as most of those chucks have two rings, the narrow one towards the drill itself being attached to the motor. However, make sure the screw inside the chuck is tight first -- I've seen those back out and block chucks open.
Posted on Mar 07, 2010
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
How to change brushes
on the BHP451 there are 2 screws on the back cover that need to be removed and then you can access the brushes and on the BTD 140 the same is true. The part number I see is 194427-5. If I have helped in answering your question would you please vote accordingly and thank you.
Jun 05, 2011 | Makita LXT202 BHP451 18 Volt Hammer Drill...
My Makita BHP451 Li ion battery drill periodically the varible speed does not work, ie. the button works as a on/off switch - any idea what's wrong. Thanks Bjarne
Bjarne, odds are the variable speed function of the trigger is failing. There are Makita repair centers that perform repair, and sell parts if you want to take it on as a DIY project. Before proceeding, I would make sure the warranty has expired. If it is still in warranty a Makita repair center should repair it for no charge.
Dec 19, 2010 | Makita LXT202 BHP451 18 Volt Hammer Drill...
How to fix or replace a electric brake problem on a makita bhp451
you would need to replace the switch, but before doing that check the brush length for excessive wear. you can go to Makitatools.com for a breakdown for this model.
Nov 29, 2009 | Makita LXT202 BHP451 18 Volt Hammer Drill...
18v makita bhp451 cordless hammer drill.clutch slipping
its prob stuck between gears one and two try a little wd40 on the gear selector switch
Jul 18, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Makita BHP451 Question
Buy a hitachi li-ion 18 volt ds18dl.
All parts are repairable & replacebable should they breakdown. Ie gearbox.
Gearbox parts are not available on makita , only whole gearboix which can be expensive.
Cheers
Laurie
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
117 people viewed this question
Top Makita Drills Experts
efs_perpends
efs_perpends
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
