The error code 59 on the Faema E92 Elite A Automatic A/2 Espresso Machine indicates an issue with the pressure sensor signal. Here are some possible causes and solutions:
Sensor Failure:
Check the cabling to ensure it's properly connected.
If the sensor is faulty, replace it.
Card Failure:
Verify if the control card is functioning correctly.
If the card is defective, consider replacing it.
If you've ruled out sensor and card issues, it's advisable to consult the machine's user manual or contact a professional technician.
You're looking for part number 3301135601. I've come across a few Smarts with Due front panels - so measure your keypad: if it's 68x58mm you need a Due version instead.
Assuming you've got a grind which brews out correctly when manually brewed.....
Fill and tamp a portafilter, ready. Press and hold 'stop' pad until machine beeps. Tap the pad you want to program. Lock in the portafilter. Press and hold the pad until you get the volume required. Press 'stop' to exit programming, the machine will stop beeping.
It can be many things. If I understand machine start working (pouring water) itself, otherwise not working. Probably your touch pads is bad, must be replaced. If I now more about problem mighty I can help more.
