What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. If you have any other AC Repair Questions don't be afraid to let us know.
Haier offers window and portable AC units to fit your space and keep the temps ... Haier window air conditioner ultra quiet serenity model. ... Coming in at 43 dBA, it's the quietest window AC on the market*. ... Get AC When & Where You Need It ... excess moisture is removed from the air without you having to empty the unit.
For more click here
It's a "drainage system trouble" code.
The compressor run light flashes in 10 flash increments.
You should be able to check whether condensate is draining from the unit.
If not draining, that's your problem.
try to drain the water from the unit it should have drain holes in the back of unit on the bottom make sure they are cleaned out where they can drain the condensate water out of the unit
As you have probably discovered, Haier for whatever reason, doesn't list any of the Error Codes in your Owner's Manual. To find out what "EO" means and the solution for it, you must contact Haier Customer Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
What do you do when EO shows up on your treadmill. We have tried to put the safety switch back and also replug the treadmill into AC power directly as suggested in the manual but it hasnt solved the problem.
Does the unit have an energy saver or timer feature? It should be on the top front panel of your unit. If so, read and follow the directions in your manual. If you still have problems, contact Haier at their toll free Customer Service helpline.
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in.
This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work.
Something else you can do is download and look through the Users Manual for your model, which is at this URL: -->
http://www.haier.com/products/product.asp?proID=3705
Hope this helps! ;)
http://www.haier.com/products/product.asp?proID=1797
Hope this helps! ;)
