Kitchen Ranges Logo
Freddie Cooper Posted on Jul 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
I have replaced the control board today because the old control locked the oven door and we had a difficult time getting it to open.
Nater13
Level 3:
Master:
  • Maytag Master 610 Answers
  • Posted on Jul 12, 2016
Nater13
Maytag Master
Level 3:
Master:
Answers
610
Questions
0
Helped
242321
Points
2229
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Have 20 year old Maytag convection wall oven. Model CWE9030B. It started beeping with a F7 display. Did stop beeping with oven light on and door open. Any advice?
The F7 error code indicates that there is a problem with the buttons of the control panel. The code comes on when two or more buttons are stuck at the same time. The oven cannot operate when this condition exists. The oven is repaired by replacing the control panel with a functioning one. You may try to tap on the control panel lightly to see if one of the ttons is stuck down.
MY OVEN DOOR REMAINS LOCKED AFTER CLEANING. I GET A F1 DISPLAYED. I LEFT IT UNPLUGGED ALL NIGHT AND IT STILL SAYS THE SAME THING AND IS LOCKED. IS THERE ANYTHING I CAN DO?
I could be more specific with a model number from the range.
The F-1 code on most ranges is a bad electronic control board. The oven lock is controlled through this board.
If you replace the board you should be able to open the oven.
You may also have a blown thermal fuse behind the rear panel on the oven as a result of self-cleaning.
Self cleaning is a nice feature but is not recommended by appliance repair technicians.
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
2helpful
Maytag electric oven Model MER5755QAQ will not heat past 100
Sorry to say but the erc or eoc has gone bad. The oven control is part # 74009212 at about 200.00. Sorry for the news but it is the problem. Hope this has helped.
2answers
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
6helpful
Readout is stuck on 5Ab. Can't do anything with it
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
1helpful
Replacing control board
There are two screews onder the shield. You need to get level with the shield to see them. Remove the two screews and it should come off no problem. Now to get in to the controll panel you have to pull the oven out and there are two screews on the back in both top corners to get in side to the control board. Good luck
How do I find the control board in a Maytag MER5755QAQ range?
you have to pull the stove out from the wall. There is a plate on the back that you have to take off and it will expose the clock.
Too hot
more than likely if it isnt shutting off when it reaches temp. then it probably needs a temp sensor or a EOC (electronic oven control). I have replaced many of these boards in the past , usually there is a relay on the board that is stuck. The relay really isn't replaceable and the whole board needs to be replaced. Does the dispay show the temp that the oven acually is or the temp it is set for?
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
