Computers & Internet Logo
How can i us wlan or wifi on my desktop - Computers & Internet
Posted by Nahom solomon on
The BRM Learning Center
    Habit-Forming:
    Scholar:
  • 58 Answers
Most older desktop motherboards are not set up with Wi-Fi capability, the fastest, easiest and cheapest way to add Wi-Fi to your desktop is to purchase a USB Wi-Fi adapter.
I've used the Panda Wi-Fi adapters (Available online, such as Amazon.com) or pretty much any computer store).
Examples:
Amazon com Panda 300Mbps Wireless USB Adapter Windows Vista 7 8 8 1 10...
Amazon com Panda Ultra 150Mbps Wireless USB Adapter Windows XP Vista 7 8 8...
An alternative would be to purchase a wireless NIC card to install into your Desktop PC. You would have to examine your PC to determine what form factor and technology to purchase that would be compatible with your motherboard and available expansion card slots.
Posted on Jul 06, 2016
3answers
What to do when model Z796C Keeeps searching for wifi network
go to settings, wireless & network, WLAN settings, turn off your WLAN by unchecking or unmarking it.
2answers
Hi I'm trying to use my desktop pc with ASUS P5Q3 Deluxe Wifi AP @n motherboards onboard WLAN as an Access Point to my Nokia X3-02 phone for WLAN. Would be nice to use same internet connection through...
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect to your phone
hope this helps
Can i connect wifi on my phone without wlan?
Hi, the WIFI is accessible only through WLAN feature of the phone it is mean for accessing WIFI. Without it, it's not possible to access the WIFI for the Cellphone.
5helpful
Does an emachine e627 have a wifi built in?
Yes the emachine e627 does have built-in WLAN (Wi-Fi).
From the manual:
Communication
• Integrated webcam*
• WLAN: IEEE 802.11b/g
• LAN: Fast Ethernet; Wake-on-LAN ready.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
6helpful
2answers
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
5helpful
3answers
HTC Touch Wifi Drivers
i dont understand y do u need them on ur pda or ur desktop pls elaborate ur need
Hi i have an Acer 592o and can no longer connect to the internet. Says it cannot find LAN or WLAN?
look like  ur wifi is off, try to press the wifi key to switch it on, if still not working let me know.. b1d2837.jpg
Wlan dosent connect to net work
Make sure that your wlan is on, search your wifi ap broadcast by doble click wlan icon under the top corner desktop, double click search if wifi ap appear you can connect by doble click connect bar, if wifi have security you must write or set the security setting like wifi ap by consult with admin wifi. In order to best conection you must in range of wifi signal not so far from your ap.
2helpful
Wifi not working
Your WiFi works only if your phone is in a WLAN network.Select Menu>Tools>WLAN Wizard.The phone will automatically search for availiable WLAN networks.Select the desired network.Click Options>Start Web browsing.The phone will automatically create an acces point and you can browse the internet.
2answers
Ipaq 6515 & WLAN?
Buy a WLAN sdcard to get WiFi connectivity. You will still have the second minisd slot available for a memory card.
Marvin
Marvin
