You can't select its input without a remote control. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
SOURCE: whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
install your cellphones with tv remote.. download that from www.mobile9.com.. you can use that to remote you TV.. depends on your cellphones..
SOURCE: Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
SOURCE: 1987 RCA Colortrak 2000 Television
Line 1 is Channel 91, Line 2 is Channel 92 - you can select them directly using the remote
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
